It is currently Mon Jul 28, 2025 5:32 am
 Post subject: Low Tech Pin Router
PostPosted: Thu Mar 20, 2008 10:29 pm
Greetings
Here's a pin router for inlay made from a Dremel drill press with some mods. I used a 1/32 bit from LMI and a 0.035 pin. I had to make some mods on the depth stops which suck on the original press. I had a Corian negative made for my logo by the same place that CNC's it. Stick it on the back of the headstock veneer with double stick tape. I've used it on several head plates and it works slick. Got the idea from Charlie Hoffman's web site.
Terry
 Post subject: Re: Low Tech Pin Router
PostPosted: Thu Mar 20, 2008 10:50 pm
Cool !!! Looks like it gives some tight fitting inlays and is easy as pie too. My kind of jig !
PostPosted: Fri Mar 21, 2008 10:38 am
great idea!
Thanks for sharing!
PostPosted: Fri Mar 21, 2008 11:01 am
Terry, Thats pretty slick. What is your inlay material?
PostPosted: Fri Mar 21, 2008 11:55 am
Very cool Terence!
I'm assuming you are not actually inlaying solid parts in there but rather filling with some colored epoxy or something?
I was looking for a way to right "Moisan" on my truss rod covers, now I have just found it!
Alain Moisan
(Now building just for fun!)
PostPosted: Fri Mar 21, 2008 1:33 pm
Alain,
The inlay is in two parts. the K and the ennedy. The hole in the y and d are filled with wood dust and superglue. I'm sure there are better ways to do this. Sometimes the center of larger y hole will remain, other times it splits out.
Terry
PostPosted: Fri Mar 21, 2008 1:35 pm
Inlay material is MOP but I'm looking at the possibility of Ablam. They are really fragile.
Terry
PostPosted: Fri Mar 21, 2008 5:51 pm
Last Name: Garrish
The abalam is no less fragile than the pearl, maybe moreso, though it does bend a bit before it breaks. It's just the nature of the beast; you could bend a chunk of aluminum cut that thin pretty easily even.
Bob Garrish
PostPosted: Fri Mar 21, 2008 9:35 pm
Do you have another pattern to cut out the MOP?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Sat Mar 22, 2008 9:00 am
"Do you have another pattern to cut out the MOP?"
I farm that out Ricardo
Terry
