It is currently Mon Jul 28, 2025 11:54 am
 Post subject: Tru Oil wait time?
PostPosted: Thu Mar 27, 2008 4:35 pm
I'm using Tru Oil as a finish right now on one of the two guitars on my bench and its building up nicely. How long do I need to wait on Tru Oil before I work through the grits and get it up to a nice gloss?
-j.
-jack handy
 Post subject: Re: Tru Oil wait time?
PostPosted: Thu Mar 27, 2008 4:44 pm
I'll be using that as well and am curious too. Please post picks of the finish when done. [:Y:]
PostPosted: Thu Mar 27, 2008 4:56 pm
So many people rave about True Oil for necks. My experience is that it starts feeling pebbly after a while. Maybe its a reaction of my skin oils with it? I prefer water-based lacquer on the neck - no problems. I have finished the body of a uke with the product and its seems fine for that.
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Thu Mar 27, 2008 6:06 pm
I like it very well as a satin neck finish and it seems to hold up great for me. I was hoping to get some answers on the gloss, though.
-jack handy
PostPosted: Thu Mar 27, 2008 6:15 pm
Jack, I don't think True Oil can be brought up to a high gloss, semi-gloss yes.
Rich Smith
Issaquah, WA
PostPosted: Thu Mar 27, 2008 6:39 pm
First name: Jim Howell
The photo is a mahogany neck done in Tru-Oil. I waited about two weeks before going up through the Micro-Mesh grits. I do like it for necks.
Jim Howell
Charlotte, NC
PostPosted: Thu Mar 27, 2008 7:41 pm
Jim that's a nice finish for true oil! I'm working on a dulcimer and will finish it with true oil bliss . I have seen some really nicely finished gunstocks done with tru-erl.
PostPosted: Fri Mar 28, 2008 1:36 am
I finished a guitar with it for a Christmas present last year...was under the gun to finish, and TruOil was the prefect answer. In my experience, I rubbed it right on with my bare fingers and wiped off ONLY the excess...but be warned, it sure gets tacky fast.
I applied two coats in one night for three nights...let it sit for two more, then leveled and applied one more coat. Hand buffed two days later with a very soft cloth. All in all, a very nice (and thin) finish.
PostPosted: Fri Mar 28, 2008 9:28 am
Oh, Jack! ;)
PostPosted: Fri Mar 28, 2008 10:26 am
I have no problem taking tru-oil to a high gloss sand through 2000 and micromesh through 12000 by hand and hit it with the buffer fine and extra fine. I usally let my neck set for 15-20 days before rubbing out. but that has more to do with my build schedule than cure time.
PostPosted: Fri Mar 28, 2008 10:33 am
Excellent info. Thats kinda what I had in mind, but wanted to see if that was a method anyone else used.
Michael, would you mind sharing your application schedule/method? Or, if you've posted before, maybe just a link. I couldn't find it when searching the archive.
Thanks.
-j.
-jack handy
PostPosted: Fri Mar 28, 2008 10:42 am
Pore fill with Zpoxy via index finger. Allow to cure over night. Sand back to near wood. Do a 60%/40% alcohol/zpoxy wipe down allow to cure over night. light 0000 steel wool tooth the neck rag on tru-oil no more than 2 sessions a day. 6-8 sessions to build film. allow to cure out do any required leveling then rub out as I described above.
PostPosted: Fri Mar 28, 2008 11:26 am
Location: Between Bordeaux and the Atlantic. S.W.France
I've now heard a few people on this forum (and others) say that you can't get a gloss finish on Tru-oil and it's simply not true. However, the wood you're applying it to can affect the length of time it takes to harden and I expect the rosewoods will be the worst. My first experience was using it on padauk and I found that rubbing down with wire-wool the next day I was taking it all off again and I finished up with a sort of satin finish. That was OK because that's what I wanted.
But on the next instrument I put several coats on and then left it for about 2 weeks. When I tried rubbing it down with dry wet'n'dry paper it came off as white powder. This is what Birchwood-Casey says it should do. I then polished it by hand with Brasso (good old British metal polish, what the military used to use on their buttons and buckles) and it came up like a mirror. Literally, I could see my face in the reflection on the ebony heel cap.
Users browsing this forum: Bing [Bot], meddlingfool and 20 guests
