It is currently Mon Jul 28, 2025 5:19 am
 Post subject: Truss Rod Oops
PostPosted: Tue Apr 01, 2008 3:12 am
I'll try to make this quick because it is pretty late. I am still up because I have been working on uninstalling my truss rod. I tried to slip under the radar and PM'd j.Brown (btw thanks again!) and asked the orientation of LMI's U-Channel (Martin style) truss rod. I didn't let on that I had already glued the blasted thing in. I did a couple tests before installing it and when turned clockwise, it did what I though should happen and bowed back on the tape side. So that is the side I put down in the slot (no glue yet) and the put the strip (with polyurethane glue) down over it and clamped her down. After more research and even a call to LMI - I was informed the tape side should be up, and that it is in fact a double action rod. [headinwall] [headinwall] [headinwall]
I went back and forth but then decided to pull it out if possible. I did a little prying before I remembered heat was the antiglue and so I hit with an iron for just a bit and it ended up coming out pretty easy with a little upward prying from the adjustment end.
I am nervous now though that 1) I could have left it as-is and 2) now I should possibly replace it for fear that any of my prying screwed it up. I checked it both ways and it seems to be ok, does anyone have a good reason I should or should not use it?
Whatever the final outcome, now there is one more thing I will not end up doing again (hopefully)...
Thanks all!
Christian
Christian
 Post subject: Re: Truss Rod Oops
PostPosted: Tue Apr 01, 2008 3:58 am
First name: Martin
Last Name: Edwards
SHOULD be ok if it looks ok, but then how much is a new one?
some will say better safe..........
opersonally?
I'd stick it back it!! :lol:
PostPosted: Tue Apr 01, 2008 6:48 am
Put it in a vise and test it by turning so that it bends in either direction. If it doesn't show any signs of problems I would use it. I always test my truss rods before installing them.
David White, Toronto
PostPosted: Tue Apr 01, 2008 7:04 am
What David said - I always test my rods too out of the guitar - some rods have had the weld at the adjustment nut fail which is something that you do NOT want to have happen on an installed rod. If it checks out OK out of the guitar it is probably good to go but there are never any guarantees.....
PostPosted: Tue Apr 01, 2008 9:16 am
I thought the tape side WAS supposed to go down. You sure you talked to someone knowledgable.
PostPosted: Tue Apr 01, 2008 9:21 am
First name: Martin
Last Name: Edwards
put it in a vice
turn the nut clockwise.
if the other end drops it's fretboard up.
PostPosted: Tue Apr 01, 2008 10:14 am
I think you had it right to start with. If not, I'll be ungluing the one I just installed. :(
Horton, MI
PostPosted: Tue Apr 01, 2008 10:17 am
You have it correctly installed.
PostPosted: Tue Apr 01, 2008 10:38 am
Thanks for the input guys. So I did test it and it seems to work fine... so my question is when I put it back in, which direction? "Guest" and Kirt both seem to think the way I had it is probably correct. The rod did flex both directions but the flex certainly seemed stronger on the open (tape) side when turned clockwise. The guy I asked at LMI didn't sound particularly sure, and then while holding the phone a little way away from his mouth shouted "hey! the tape goes up right?"... "yeah, the tape goes up". idunno
Christian
PostPosted: Tue Apr 01, 2008 10:39 am
Grumpy beat me to it. Thanks! I guess I'll put it back the way I had it. oops_sign
Christian
Users browsing this forum: Michaeldc and 17 guests
