It is currently Sun Jul 27, 2025 11:49 am
PostPosted: Tue Apr 22, 2008 7:16 pm
Hello all,
I'm making another bass guitar now and am considering giving the top a radius. I thought about making the top a section of a sphere, like the top or back of an acoustic. Another thought is to give it a cylindrical radius so that the top tapers of to the sides, but stay straight in the direction of the strings. The reason of the latter is that, if I give this thing a cylindrical radius then I suppose I ought to have the high point coincide with the bridge location. On a bass guitar the bridge sits way at the back which may make that body too thin in the upper bout region, or the neck area.
Perhaps I should also add that I'm going to make a floating bridge on this one.
I tried to find some carved top bass on the web but have come up short. Is this done often?
Thanks for any thoughts/advice on this matter,
Stefan
PostPosted: Thu Apr 24, 2008 10:38 pm
First name: Brett
Last Name: Faust
City: Puyallup
Zip/Postal Code: 98373
Check out Fender Aerodyne.
How long is that in luthyears?
PostPosted: Fri Apr 25, 2008 4:50 am
First name: Martin
Last Name: Edwards
with the bridg so near the edg then a dome will have the neck join VERY low.
what about slopin away on three sides?
'know, top, bottom & tail sloping & neck join level with the bridge.......
there are a load of layered basses out there with bevel cuts that let you see the lams.....
here'sa few made by my mate skelf on the Jam Session
http://jsguitarforum.com/forum/showthread.php?t=55832
