It is currently Mon Jul 28, 2025 12:08 am
PostPosted: Wed May 07, 2008 4:57 pm
Hi all.
I need to cleat a crack that occured on the lower end corner of a dreadnought top. When attempting to reach it with my arm, I just baerly can make it to the top of the crack; I would need about 3 inches more on my forarm! So I'm going to have to make myself a jig to reach there and apply pressure to an area of about 3/4" by 3".
Anybody ever had to do this? What jig did you use?
Thanks!
Alain Moisan
(Now building just for fun!)
PostPosted: Wed May 07, 2008 5:17 pm
I often use the sharp end of a soundpost setter.
PostPosted: Wed May 07, 2008 5:35 pm
Last Name: Garrish
A couple rare earth magnets stuck to a small piece of wood should do the trick.
Bob Garrish
PostPosted: Thu May 08, 2008 6:52 am
Thanks for your responses guys.
David: what does a sound post setter looks like? And how do you use it exactly?
Bob: Yes, I am totally going to get myself some rare earth magnets, but I don't have the time to wait for the mail order. The guitar should come in today.
So if anyone as other suggestions, I'm listening!
Thanks again!
Alain Moisan
PostPosted: Thu May 08, 2008 9:00 am
Frank Ford shows this nifty long reach clamp he made on his frets.com website.
PostPosted: Thu May 08, 2008 9:54 am
It's just a flexible strip of metal with a notched flat on one side for manipulating sound posts, and just a sharp tip on the other. I stick a cleat to the sharp end, dab on a bit of hide glue, and press it in to place for a quick rub joint. I use magnets occasionally, but for most jobs this is all I do.
If you're using hot hide glue all you need is any long arm to stick the cleat on that is malleable enough to shape to your needs, and stiff enough to put a pit of pressure to rub it in place. A $3 "S" soundpost setter is perfect for this. Add light and mirror inside the guitar, and it's easy.
PostPosted: Sat May 10, 2008 6:15 pm
Thanks for clarifying that David.
Alain Moisan
PostPosted: Sat May 10, 2008 6:51 pm
You can cut a custom tool out of 3/4" plywood that is about 1" wide with a straight handle and a long curve that fits through the sound hole contacts the back and continues up to where you want the cleat. With the handle you can lever up to the underside of the top. The shape is roughly like a sickle. A few minutes on the band saw and you have a tool that is exactly the right reach length. Double stick tape the cleat to the tip of your tool.
PostPosted: Sat May 10, 2008 10:22 pm
Thanks Steve.
That's what I had in mind in the first place, but thought I'd ask to see if someone had a better idea.
I guess that'll have to do!
Alain Moisan
