It is currently Sun Jul 27, 2025 2:38 am
 Post subject: sharpening router bits?
PostPosted: Mon Jun 02, 2008 8:37 pm
does anyone have a technique for sharpening router bits? at $20.00-$30>00 a pop it seems like a neccesity , thanks Jody
PostPosted: Tue Jun 03, 2008 12:20 am
Last Name: Garrish
If you don't need a bearing on it, my carbide mills cost me a lot less than most people are paying for HSS router bits and they essentially last forever cutting wood. Sort of a problem avoidance strategy, I suppose, but you can get a 1/2" 2 or 4-flute carbide end mill for under $20. It's crazy what the same cutters for for as 'spiral router bits'. If it's got a bearing on it then I've got nothing for ya unless you're fast enough to use the shank without burning...
Bob Garrish
PostPosted: Tue Jun 03, 2008 5:09 am
Thanks , it seems like a round diamond file ( and magnifying glasses)would work for round over bits too ... ! jody
PostPosted: Tue Jun 03, 2008 5:25 am
I use carbide end mills in my pin router - they give amazingly clean results. Love 'em!
PostPosted: Tue Jun 03, 2008 6:47 am
I bought a diamond sharpening wheel from a guy at the big wood shows who sells resharpened drill bits from the aircraft industry - those bits are amazing as well, and fairly priced. The wheel was 20 bucks I think ...
Anyway, the wheel goes in my dremel, and I have only used is a couple times, but it did a great job .. It saved the little 3/8 top bearing bit from SM for template routing from the trash this way. It had seen way too many PU routes, and was really dull .. no more.
