It is currently Sun Jul 27, 2025 6:35 am
PostPosted: Tue Jun 03, 2008 6:07 pm
Hi everyone... working on setting my Les Paul up with 11's now. Yes, after playing acoustic for so long the 10's feel like they aren't there and I'm used to fighting them... HARD. All that said, the pickups in my Les Paul were custom wound from vintage magnets left over from deceased original PAF humbuckers. They are completely microphonic, as is my wish. I've adjusted the edge polepieces as far down as they will go and to the factory specs of distance to the underside of the strong both at the neck PU and bridge PU. Now, how should the polepieces be configured-- conforming to the radius (i.e., the same distance from the polepiece to the bottom of each string) or staggered like a stratocaster pickup (i.e., some higher than others)? If they should be staggered, can anyone provide me with a good measurement of distance from the top the the polepiece screw to the bottom of the string for all six strings on both pickups? Incidentally, I may decide to go back to 10's later... I'm missing the screaming notes coming from the E string now that I've restrung with 11's... I guess sometimes heavier is not necessarily better, but for the moment, I'm relatively satisfied. With the polepieces conforming to the radius (so to speak), the guitar is very dark sounding and I really miss the bell-like ring of the highs. :-( May have to do some more adjusting. Any and all advice is greatly appreciated. Also, please forgive me if this is not posted in the correct place, as it does pertain to an electric instrument rather than an acoustic. Thank you all!!!!
PostPosted: Tue Jun 03, 2008 6:15 pm
In the end, you do it by sound, with the main point being to get the string volume balanced. In practice, I have found that this means roughly the same arc as the board radius, but dropping the height under the lowest plain string (the G in Rock & Roll sets) a bit, and raising it a bit under the first wound string (D). The winding and the change in core diameter makes the D sound less brilliant; this compensates somewhat for that.
Users browsing this forum: ChuckB and 18 guests
