It is currently Sat Jul 26, 2025 7:11 pm
 Post subject: Hide glue pot
PostPosted: Thu Jun 05, 2008 10:33 am
I know there's been some discussion of this, but I couldn't find it in the archives. What are those that are using HHG using for a glue pot?
Jimmy Caldwell
 Post subject: Re: Hide glue pot
PostPosted: Thu Jun 05, 2008 10:36 am
Jimmy I picked up a Rival Hot Pot a few months back at a garage sale. It works great and sure beats paying over $100.00 for a 'glue pot'. I think you can find them new for less than $20.
PostPosted: Thu Jun 05, 2008 11:36 am
First name: George
Last Name: Thomas
Hi:
For the users of crock pots for hide glue, how do you control the temperature? I did buy a crock pot from a local good will store for $10 but it, like all of them there, had two temperature settings. The "high" setting was around boiling and the "low" setting was around 120 degrees F. I do not mean to sound like Goldilocks here but how to get to and hold the correct temp?
GEO
perpetual beginner
PostPosted: Thu Jun 05, 2008 12:00 pm
Jimmy,
Are you talking about a "glue pot" that a production or large repair shop would have kept in days of yore, filled with glue and a couple of glue brushes sticking out of it?
If so, I'd go for something like this at LMI, with temp control.
http://www.lmii.com/CartTwo/thirdproducts.asp?CategoryName=Specialty+Tools&NameProdHeader=Brass+Glue+Pot
or this at International Violin
http://www.internationalviolin.com/item_detail.aspx?ItemCode=T82
Open pots like these add that special "hot hide glue ambiance" to any shop!
For temperature control on my cheapo Rival crock pot, I use my router control from my bending blanket. I seldom need to glue and bend at the same time. :D
PostPosted: Thu Jun 05, 2008 2:12 pm
The other option is a baby bottle warmer. About $16.95 art Wal Mart. Will keep it on temp all day, if you don't mind the look. Has a temp knob that works great. You just have to add water from time to time, as it evaporates or cooks off.
PostPosted: Thu Jun 05, 2008 4:34 pm
Another vote for the baby bottle warmer. I bought mine off Ebay for about $5. It will hold the glue temperature to with a couple of degrees F all day long.
PostPosted: Thu Jun 05, 2008 4:41 pm
PostPosted: Thu Jun 05, 2008 7:02 pm
I bought a leg wax warmer on ebay pretty cheap.And didn't my wife's eyebrows raise when I walked through the door with that wow7-eyes.
Most of these things have a little pot inside them where you can set the temp. I don't use the temperature knob on the outside of the thing, I turned the knob up to 10 and pulled the cover off and set the temp internally with a decent thermometer in the water bath. It'll never overheat my glue, stays at between 60-62 deg C. Gotta be careful while you do this 'cause you're mixing water with exposed electrical terminals, but it's much better than using a sharpie to put marks on the knob and having to check that the marks are lined up everytime you use it.
PostPosted: Thu Jun 05, 2008 7:43 pm
George Thomas wrote:
Hi:
I took mine apart, found the trim screw, turned the main control all the way up, and adjusted the trim till the temp reduced a bit. Not perfect, but cheap
PostPosted: Thu Jun 05, 2008 8:42 pm
I've been using a Presto Fry Daddy for a few years. Removed the bottom, located the thermostat, drilled a hole in the bottom over the thermostat, adjusted it to stay 140 degrees.
PostPosted: Thu Jun 05, 2008 9:42 pm
I use the smaller sized Rival Hot Pot and it works great. Prior I bought a crock pot "Little Dipper" as recommended here on the OLF and mine ran to hot, I could not get it under 155F so I pitched it.
PostPosted: Thu Jun 05, 2008 10:01 pm
Parent's Choice baby bottle warmer. Has three temp setting, #2 keeps it at 141F +/- 1 degree. I had a digital thermometer that will log highs and lows. Had it in there for over an hour so I could see how it was cycling. I started with an older Rival hot pot that did a 20F swing. Tossed that puppy.
PostPosted: Fri Jun 06, 2008 7:53 am
Last Name: Killin
Don't be fooled by a "Rice Cooker." I got the small rival rice cooker with two temp settings. It runs hot for this purpose. Of course I have never actually gotten to the point of using Hot Hide glue yet, but now can officially cook rice. All in all, not the same as a crock pot.
PostPosted: Fri Jun 06, 2008 5:46 pm
