It is currently Sat Jul 26, 2025 6:31 pm
PostPosted: Wed Jun 11, 2008 6:49 pm
Does anyone know what the little spring holders on the Everett Side Bender are called? If you do, do you know where I can get them?
Bill
Formerly know as Mandodiddle.
PostPosted: Wed Jun 11, 2008 8:40 pm
Thanks Todd.
PostPosted: Wed Jun 11, 2008 9:37 pm
FYI too John Hall at Blues Creek also sells the cauls, springs and probably the hardware too.
PostPosted: Wed Jun 11, 2008 10:02 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
http://www.mcmaster.com
Amazing site. And it will be on your door step lickity split. Never seen a company ship stuff so fast.
PostPosted: Thu Jun 12, 2008 9:00 am
Last Name: Sollod
I looked at the mcmaster site for the clamping wheel assemly at the top of the bender, but I don't know what its called. idunno ...anybody...?
www.swiftcreekguitars.com
PostPosted: Thu Jun 12, 2008 7:59 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
Steve,
They have some listed under "stud knobs", under the "revolving Handles" title. I don't
know if the studs are long enough for you. Another alternative is to get a "threaded
hole handle" and cut a section of threaded rod to the right length, then use cyanoacrylate
glue to hold the handle and rod together.
Gene
PostPosted: Thu Jun 12, 2008 10:39 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
This may be more appropriate for the Fox Bender, but Mcmaster lists something called a "press screw". Comes with the handle, screw, and base mount.
The trick with Mcmaster is to know what to call it... two days later its on your doorstep. Might try their "express" delivery service... got be like "mouse click" and "ding dong" 2 minutes later.
PostPosted: Fri Jun 13, 2008 10:34 am
First name: Gene
Last Name: Zierdt
City: Sebastopol
Grizzly also has a press screw available- I got one for my cutaway caul on the
bender (first cutaway- next build).
Gene
PostPosted: Sat Jun 14, 2008 11:34 am
First name: Wayne
Last Name: Clark
City: Driftwood
Bill,
You can also use mirror hangers to attach the springs. That's what I used on mine. You can get them at Home Despot.
I got the press screw from Constantine's.
Wayne
