It is currently Sat Jul 26, 2025 6:09 pm
PostPosted: Tue Jun 17, 2008 9:37 pm
Hello all,
I am testing on scraps still with the rockhard varnish. So far it really is easy to apply and looks great. However, the end result I want is a satin finish. My procedure for doing this is:
1. When left to cure for 2 weeks sand from 600 to 800 to 1000 dry then use 0000 steel wool to finish....and that it is it.
Does this sound ok to you? Aside from using a satin finish what are your favorite ways to satin up the finish?
I recall somewhere to use the wool with wax, then use it with water to get the wax off. I guess the wax is a lubricant to get more even scratch marks?
One last item....Do you know of a way to add an additive to the varnish to make it satin? I would put the last or last two coats as satin to get the final product I want with the clarity of the gloss underneeth.....I thought silica was used or something of that nature.
Thanks for any info
Matthew
PostPosted: Wed Jun 18, 2008 7:24 am
First name: Jim Howell
Matthew--
I've had pretty good luck using Pratt and Lambert No 38 Clear varnish (H17) satin to get a satin finish. You can thin it with pure gum spirits of Turpentine. Used by itself, it will give you the Taylor "110" look.
Jim Howell
Charlotte, NC
Users browsing this forum: UncleMikey and 19 guests
