It is currently Thu Jul 24, 2025 7:13 pm
PostPosted: Tue Jul 15, 2008 8:27 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
i have started my 2nd and 3rd guitars ( my first was at a workshop with Frank Finnochio) Both are OOOs I am using the usual texts for reference the notes I have from the workshop as well as some dvds. One thing I noticed after comparing references and looking inside some of my personal acoustics is that the lower bout back braces are thick around 3/4" wide in some and 5/8" in others. Obviously the 3/4" braces are much shorter than the 5/8" braces. Is there any advantage to one over the other? Also should all the braces come from the same brace wood billet. I noticed after cutting the braces for the back one brace came from a different brace wood billet and had much higher grain count ( it is all Lutz spruce just different pieces)
thanks
Richard
PostPosted: Tue Jul 15, 2008 7:04 pm
Hi there, I built a guitar with Frank too , it was a great place to start learning the craft. the guitar I built with Frank also had larger back braces meaning :
there are basicly two schools of thought on the way the back of a guitar works within the system of the guitar body . school one ,( which I call the stiff back )is where the guitar body works like a bass reflex speaker , where the back and sides are ridgid, and the top "pumps" in and out like a speaker cone.this is the way the guitar was built in Franks class.( at least mine was, and it sounds like yours was too) . in this system the braces are usualy more stout .
now the second school of thought , ( which my first solo build is following ) i call the flexible back school ,this is where the top and back are coupled in such a way that they work together , sort of like a tennis racket , guitar body with stiff sides , and both the top and back coupling together . in this system the back is, or seems to be noticably more active.in this system you can use lighter braces .
Great sounding guitars can be built either way !
so the answer to your question seems to be , you first need to decide which school you want to be in , that will determine , your brace sizes.If you are unsure , good advice at this time might be to stay with the plans you are using ! Jody
PostPosted: Tue Jul 15, 2008 7:54 pm
I am not sure but I think Martin set the standard for using wider back braces in the lower bout. My guess is that this was done for structural rather than acoustical purposes much as they stopped scalloping their top braces. It is not likely that they could hand-select perfectly quartered brace stock with no runout, as the individual luthier can do, so they were made fatter to accomodate what came off the saw.
In Markham,Virginia
PostPosted: Wed Jul 16, 2008 8:44 am
Folks, Martin didn't always use the 3/4 x 1/2" bracing on their dreadnaughts. If memory serves, pre-war martins used 5/16 x 5/8 stock for their back braces. Kevin Gallagher might be able to chime in here and discuss the whys and wherefores. Observationally, the older guitars with the taller thinner stock sounded better. That's going to be a combination of how their tops were braced and how their backs were braced.
PostPosted: Wed Jul 16, 2008 9:23 am
The same is true for some pre-war Gibsons and the lower two back braces can be approx. 5/8" wide and 1/2" or less tall and shaped like half-rounds.
PostPosted: Thu Jul 17, 2008 8:52 am
'37 D-18
'36 D-18
Lower back braces were 3/4" x 3/8" to 13/32". The upper braces used 5/16" x 5/8" stock though.
Jeremy Douglas
PostPosted: Thu Jul 17, 2008 8:55 pm
I wonder what that dead bug does to the sound of that '37 D-18! laughing6-hehe
Alain Moisan
(Now building just for fun!)
PostPosted: Thu Jul 17, 2008 10:08 pm
Isn't that a rattlesnake rattle? I've seen guys put them in their guitars. Have no idea why.
TJK
PostPosted: Fri Jul 18, 2008 8:16 am
TJK
It makes the guitar sound better, keeps spiders and mice out and brings good luck, or at least keeps bad luck away. It comes mainly from fiddle players putting them in there.
Jeremy Douglas
PostPosted: Sat Jul 19, 2008 12:37 pm
TJK
I put one inside my 1950 D-28 to let anyone who tries to walk off with it know what will happen to 'em. [xx(]
Users browsing this forum: jfrench and 24 guests
