It is currently Wed Jul 23, 2025 11:49 am
PostPosted: Sat Jul 26, 2008 10:11 am
First name: John "jd"
City: Santa Barbara
the CA will wick well but cures too fast.
look into using a slow cure laminating epoxy like west systems 105/205. That will wet out well and with a little heat will thin down and wick a long way before curing.
not a reversable solution, but it should work.
-jd
PostPosted: Sun Jul 27, 2008 4:12 pm
Todd, I also was thinking of some epoxy if you get it worked back into all of the delaminated area. Should give you plenty of working time.
Good luck!
Users browsing this forum: meddlingfool and 17 guests
