It is currently Fri Jul 25, 2025 3:21 pm
 Post subject: Air Compressor
PostPosted: Sun Aug 17, 2008 10:51 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I just found a brand new Porter Cable 2 cylinder, oiled, 60 gallon compressor for $250. Its 240 volt, 9.6 cfm, 3hp.
Good deal? Way good deal??
 Post subject: Re: Air Compressor
PostPosted: Sun Aug 17, 2008 11:16 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Right. What makes it low end?
PostPosted: Mon Aug 18, 2008 7:31 am
If it's a single stage, it's a good deal. If it's a two stage, it's a very good deal. Also check the motor RPMs. It should be either 1500 or 3450 RPM. A 1500 RPM motor will make less noise, trap less moisture and the piston seals will last longer.
Jim Womack
Will Rogers
PostPosted: Mon Aug 18, 2008 10:47 am
The other thing is what will you be using it for? 9.6 cfm might be a little low for something like a Dynabrade sander.
Terry
PostPosted: Mon Aug 18, 2008 7:39 pm
Last Name: Garrish
A 5HP DevAir will put out over twice the CFM of a 5HP Porter-Cable, they use a much looser definition of HP than the higher-end manufacturers. On the other hand, DevAir doesn't compete in anything near that price range, either, as they're more industry-oriented.
Bob Garrish
PostPosted: Mon Aug 18, 2008 11:45 pm
First name: Greg
Last Name: Harrington
Buy it.
Greg
PostPosted: Tue Aug 19, 2008 5:26 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
If I do not buy a fuji HVLP, I may get this. The compressor offers more usefulness. I do not plan on using heavy air tools... finish spraying, filling tires ;) etc.
Users browsing this forum: Glen H and 30 guests
