It is currently Tue Jul 22, 2025 1:35 am
PostPosted: Wed Sep 03, 2008 6:40 am
I built this one last year and the customer is hoping I can fix it. EEEK!!
The top also has 2 small cracks along the lining.
PostPosted: Wed Sep 03, 2008 6:55 am
It happened while inside this case. A big guy fell on it.
PostPosted: Wed Sep 03, 2008 8:17 am
It is repairable. You need some patience , lots of CA a good probe and some imagination. I bought an HD28 off Ebay last year that was crushed. That had a pair of top cracks at eash bout and the neck block sprung , this sheared the top along the neck line. The crushed side and cross crack at the tail block made it look like a lost piece.
With "golf club" spreaders you can gently open the space and work the smaller pieces into place. Use HHG or CA that is very thin. Then use wide tape to clamp. Lots of work but you can learn by doing.
john hall
Authorized Martin Repair Center
PostPosted: Wed Sep 03, 2008 1:15 pm
How to handle it? Carefully, one step at a time, with a game plan for the whole job before beginning it. I don't know how much more anyone can tell you without having it on their workbench and poking at it. It can be really amazing how well instruments split up from a mechanical injury can be made to fit back together. I don't see a big role for tape as a clamp, except for the binding. But some thin, flexible acrylic cauls will be handy for keeping surfaces flat when gluing (which is also a reason to be careful about using CA glue--you need time to align the pieces when clamping; hide glue is also problematic where you need clamp time). PVA, thinned a little bit, is the glue of choice for a lot of this kind of work. Or fish glue.
PostPosted: Wed Sep 03, 2008 3:52 pm
It looks like a good challenge. A look an Frank Ford excellent frets.com site may give you ideas on how to approach the repairs.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Wed Sep 03, 2008 8:45 pm
One other tip: If you don't know how to use "tuner" clamps, this is a good time to learn. These use a guitar string to pull in a patch behind a crack.
Users browsing this forum: TimAllen and 21 guests
