It is currently Mon Apr 20, 2026 3:12 am
 Post subject: Cutting the frets
PostPosted: Sat Sep 27, 2008 11:24 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Is there an appropriate tool set for this?
 Post subject: Re: Cutting the frets
PostPosted: Sun Sep 28, 2008 6:08 am
My tool set:
1. LMI fret cutting guide.
2. Accurate ruler and scalpel for marking up the board.
3. Guaged fret saw for cutting the slots.
I don't use a template. I measure the fret positions using the ruler and scalpel.....measuring twice and cutting once.
Cheers Martin
PostPosted: Sun Sep 28, 2008 1:07 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
ToddStock wrote:
Are you talking about trimming the to-be-installed fret or fret slotting? SM tang nipper, small mill bastard, and fret nippers for the former, and shop-made templates and SM fret slotting blade for the later.
Here's the link to the template photo essay; an entire set of 12 (Martin (4 scales), Gibson (4 scales), Fender (1), PRS/'Weissenborn scales (1) plus short and long bass scales runs under $25 in materials; once made, it's a few minutes to slot a board.
http://luthiersforum.com/forum/viewtopic.php?f=10102&t=5866&hilit=fretting+templates
For some reason this no longer shows up on the tutorials page, but it's archived.
I meant cutting the fret wire. I ordered the tools. Will a file from Lowes work? I also ordered the press arbor from LMI (for use on a drill press)
PostPosted: Sun Sep 28, 2008 1:11 pm
Mike my friend here is what I use - the blue handled nippers toward the bottom of the picture. I think mine came from Stew-Mac:
PostPosted: Sun Sep 28, 2008 7:45 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Hesh. A crow bar? And a screw through the board? I'll bite. Whats the crow bar for? Would not a shot of Maker's Mark work better?
PostPosted: Sun Sep 28, 2008 7:58 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
The tool is called an end nipper or cutter and you can pick one up from most hardware, tool, box stores. Just grind the cutter part down so that they make a flush cut. You can also use them for pulling frets. Don't use them to cut the end off strings.
Cal
PostPosted: Mon Sep 29, 2008 1:30 pm
"I meant cutting the fret wire. I ordered the tools. Will a file from Lowes work? I also ordered the press arbor from LMI (for use on a drill press)"
I was recently turned on to using a Fan Out Lead Dyke, you can get them at stained glass places, or online.
https://soundcloud.com/jeffreylsuits/he ... -runnin-13
