| Cocobolo |
Joined: Tue Jun 03, 2008 1:12 pm Posts: 466 Location: Plainfield, IL (chicago)
I find that ABS can be come brittle under lacquer...but not near as brittle as the older celulliod bindings found on the 50's guitars. I have done quite a bit of restoration on old guitars and celulliod has been much more difficult to work around. ABS seems to stay plyable for years in its raw form, but the nitro seems to dry it out some how. I can say I have never knocked off a chunk of ABS. I have loosend an end, or knocked off an entire side of the neck binding. But I have yet to see it break off in small pieces.
I have not seen any issues with wood bindings. I assume this is because you are glueing to "like" materials together. When glueing different materials together, there always seems to be a longevity issue with the bond.
YMMV Joe
_________________ Joe
