It is currently Sun Apr 19, 2026 11:21 pm
 Post subject: Guitar Strings
PostPosted: Tue Nov 04, 2008 1:52 pm
City: Grandfalls
State: Newfoundland
When I install my guitar bridge I drill the peg holes 3/16"....The strings I have installed in the past went in the holes with no problem.....Yesterday I bought a set of Martin Medium strings and the balls would not go through the peg hole....I thought all ball ends were standard....Am I wrong?
 Post subject: Re: Guitar Strings
PostPosted: Tue Nov 04, 2008 2:14 pm
Nope, I've noticed the same thing. I think the Martin ones are a wee tad bigger.
Brad Tucker
PostPosted: Tue Nov 04, 2008 3:11 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Was your first set D'Addarios ?
You can't get better strings then thiers! beehive
Get some more! [:Y:]
Mike Collins
PostPosted: Tue Nov 04, 2008 3:15 pm
D'Addarios are my favorite too.
Larry buddy string ball ends do differ. Also, a consideration is that different strings intonate differently. Sooooo.... it's a good idea to use what your customer or you prefers especially when dialing in the intonation.
PostPosted: Fri Nov 07, 2008 12:57 pm
Interesting coincidence this, as I was going to ask the world what range of size of string ends they've seen. The reason being I'm sketching out a design for a pinless bridge.
As it happens all I've got on hand here are Martin SPs. The ends on these are a very consistent 0.157 (+0 -0.001)" diameter and 0.117 (+0.006 -0.001)" long - which looks suspiciously like 4 mm and 3 mm respectively. That gives a diagonal of 5 mm which would stick if you've got a precise 3/16" hole (4.76 mm) but would fit if you'd drilled the hole oversize or reamed out as little as 0.25 mm or 1 thou.
Has anybody seen ends bigger than the Martin ones?
PostPosted: Fri Nov 07, 2008 7:28 pm
Don't know about the ball end size other than I'm certain the Martins are larger. That said, as for strings... give me Martin SP's over D'Addario's anytime. I use D'Addario stainless steel only because I haven't found another manufacturer who makes them in the same gauge. Consistency is a big thing with me... I find some sets of D'Addario's are great, others mediocre. Just one man's opinion and many others will vary. Sorry for the "threadcrap" too... :-) Been a rough day at work. [headinwall]
PostPosted: Sat Nov 08, 2008 1:35 pm
Last Name: Garrish
That should be 10 thou. I haven't had any complaints from anyone using my pinless bridges, and I'd always been using a 3/16 hole for the ball ends (all the brands of strings I'd used fit...but I never tried Martin strings so I guess I'll have to up the hole size now!)
Bob Garrish
