It is currently Fri Sep 19, 2025 4:14 pm
PostPosted: Tue Jan 06, 2009 11:20 pm
I'm putting the finish on my first, as many of you may already know since I keep asking finishing questions :oops: .
The back,sides and neck are mahogany which I porefilled and stained. I was planning on using a few seal coats of shellac then finishing with truoil. The stain was alcohol based and I'm pretty sure when I *rubbed* on a seal coat of shellac over my stained neck some of the stain got smeared a little. Does that sound probable? Maybe it was streaky before I just didn't notice it idunno
So I was thinking about just putting the Tru Oil directly on the stained back and sides. This shouldn't cause a problem should it? I still plan on sealing the top(spruce) with shellac then finishing it with Tru-Oil.
Any advice? Can anyone confirm that rubbing shellac (dissolved in alcohol) over an alcohol based stain will smear it? What are your thoughts on the Truoil affecting the tone by being applied directly on the wood of the back & sides?
Jeremy Douglas
PostPosted: Wed Jan 07, 2009 12:31 am
Yes that would smear it. Tru-Oil should be fine. Why not try it on some scrap first? That's what they make scraps for. ;)
PostPosted: Wed Jan 07, 2009 9:17 am
Thanks Mike. Yeh, I know 'test on scrap' but the mahogany pieces I have are small and flat. What works on my scraps doesn't necessarily work on the curves of a neck or sides, which I found out by attempting to rub on tinted shellac...worked great on the scrap piece, not so great around a headstock with a volute.
Thanks again [:Y:]
Jeremy Douglas
PostPosted: Wed Jan 07, 2009 11:52 am
No problem, Jeremy. Sometimes I forget that not everyone has the scrap collection that I do. I am a serious packrat. It's a problem. :D
Users browsing this forum: TimAllen and 41 guests
