It is currently Sun Sep 21, 2025 6:53 am
 Post subject: String Size
PostPosted: Tue Feb 10, 2009 6:01 am
I assume that thicker strings are louder.
If you feel that your guitar is lacking in some freequency area does it make sense to increase the string size for that area.
For example: If your bass seems to be less than balanced with the higher frequencies would it make sense to use a little thicker strings on the 2 or 3 lower ones?
 Post subject: Re: String Size
PostPosted: Tue Feb 10, 2009 7:07 pm
First name: Olivier
Last Name: Gauthier
City: Montreal
State: Quebec
I might well be wrong, but I don't think that bigger strings will get you what you want. Out of curiosity, what kind/brand of guitar is it?
Bigger strings will give you more tension, therefore more output, more volume, and depending what kind of strings they are you will change the tone a bit. But definition, or lack of, is due (I believe) to the guitar itself, the bracings, the materials, etc.... If you put bigger strings on, let say, your 6th and 5th strings, these strings are maybe going to be louder but you are not going to increase the bass response of the instrument.... theyre gonna be louder whatever notes you play on them ;)
As I said, I might be wrong, but thats from what I have seen and heard so far...
Olivier Gauthier
Montreal, QC
Users browsing this forum: Geocoucou79 and 30 guests
