It is currently Sat Aug 23, 2025 5:30 am
 Post subject: Need a mold.
PostPosted: Mon Apr 27, 2009 9:09 am
First name: Victor
Last Name: Seal
City: Trenton
Zip/Postal Code: 48183
I am getting my ducks in a row to start my first guitar from scratch. I am going to purchase a Dred mold and I would like your opinion on the various styles that I have seen. What model/type do you use and what are the advantages and disadvantages? I will be purchasing it from one of the OLF sponsors. Thanx, Vic (8string).
 Post subject: Re: Need a mold.
PostPosted: Mon Apr 27, 2009 11:04 am
I suggest calling John Hall of Blues Creek. I have two of his molds and they are super. So is John.
PostPosted: Mon Apr 27, 2009 11:31 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Everything John sells is great. I've made all my molds but if I need anymore I'm going to get them from John instead of going through the hassle.
PostPosted: Mon Apr 27, 2009 12:01 pm
Thirds on John Hall. I've got two of his - they're excellent.
PostPosted: Mon Apr 27, 2009 12:05 pm
First name: Darryl
Last Name: Young
State: AR
John Hall......he makes the molds sold by the Martin store.
PostPosted: Mon Apr 27, 2009 12:29 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I think this hobby is expensive enough as it is... molds are easy enough to make, and any guitar making tools can be used to make a mold as well. All you need to do is trace half of the outline to a piece of plywood or MDF or whatever scrap you happen to have. Then once you got one half made you can make 3 more, or 5 more depending on how thick you want the mold to be, and get one perfect and use a router or robo-sander to trim the rest to the exact size of the first one. Then you glue all the pieces together, and you got a mold. Expanders can be made with a piece of wood the right size that are wedged in, or two matching pieces of wood for the inside contour expanded by a turnbuckle, or whatever. Making a radius dish is harder (lots of dust and time) so if you want to buy anything specialized spend your money on that. Once you read enough books and watched enough videos and spent enough time at various forums including OLF, you should be able to make the jigs you need. Now if you don't have a lot of time then by all means buy a mold but remember time is money, if you buy items that has more work done for you it will cost a lot more.
Typhoon Guitars
PostPosted: Mon Apr 27, 2009 12:37 pm
I heartily recommend John Hall, too!
PostPosted: Mon Apr 27, 2009 12:39 pm
Tai Fu, Victor did say he was looking to purchase one but, for sure, they can be shop built.
PostPosted: Mon Apr 27, 2009 2:15 pm
John Hall, and LMI both sell dread shaped molds.
PostPosted: Mon Apr 27, 2009 3:45 pm
I would get the blanket and steel benders from John, and make your own molds. (I would also use the blanket bending method obviously.) Painless in what can be a painful learning curve!
PostPosted: Mon Apr 27, 2009 5:19 pm
First name: David
Last Name: Engel
City: Stanwood
Hi All,
To those who are preaching "build your own mold"... to the prospective builder I say this: You must want to build your own tooling! It's not quite as easy as tracing, cutting out and done. The inside shape MUST be perfectly shaped and very smooth! I spent a couple weeks building my classical mold years ago when production molds were not available. What do you get for $90 + shipping nowadays? A CNC cut mold to perfection and nicely finished... with no building headaches. I've talked to a couple guys in the last year who tried to build their own. Building guitars is one thing, building tooling is quite another. My .02.
Blues Creek Guitars and KMG Guitars both sell nice molds and all manner of guitar building jigs that make life much easier! ;)
God, Family, Carreer
PostPosted: Mon Apr 27, 2009 6:16 pm
I have got to say, i have built a lot of molds and i am pretty fast and efficient at it, but every time i make one i think i would be better off just buying the dang thing. $90 + shipping?!? It still takes me way more than $90 worth of my time to do it, and i am speedy now, the first couple i made took me forever to get right.
Jordan Aceto
Ithaca, NY
PostPosted: Mon Apr 27, 2009 6:48 pm
IF you dont mind getting messy, you can cut a pattern out of 3/4 MDF in about a half an hour. Then use it and a flush cut bit on your router to cut 3 more layers. Drill, pin and glue. I can make a perfect mold in about two hours. That said, the mess is not worth it ;)
PostPosted: Mon Apr 27, 2009 6:51 pm
I get my plywood for nothing, at Home depo seconds, that is why I am a fan of home build. And if you blanket bend, you need 2 molds, the second one is alot more trouble.
I also have a sanding drum with a drill press so its easier to get everything close to perfect.
PostPosted: Mon Apr 27, 2009 11:38 pm
First name: Jim
Last Name: Hansen
Until I get to the point where I feel like I have to build something that stock molds aren't available for, I'll be using molds like John sells.
Jim Hansen
PostPosted: Tue Apr 28, 2009 2:26 am
First name: Chuck
Last Name: Hutchison
City: Houston
Vic,
I done went and got me one of them there molds from Johnnie Hall (Blues Creek Guitars). They sure are purdy and put together real nice like.
I'd say go on and get ya one from him if you're a hankerin' to get one.
PostPosted: Tue Apr 28, 2009 5:32 am
Made a 000-bought a slope dreadnought from John. Buy John's mold. Even in tight economic times, I say "Dance with the one that brung ya." John contributes so much more than products. So, that additional generosity should be rewarded. Besides, you cannot find a mold to equal his at anywhere near his price. And, you can pick up(or I guess , flip open,) the phone and there is John, ready to answer your questions and never treating you like an idiot. Keep it in the family.Mike T.
PostPosted: Wed Apr 29, 2009 4:14 pm
I make my pattern from 1/4" MDF. Actually I make my body pattern from 1/4" MDF and use a inlay kit to make the outside mold pattern. Trace it onto the plywood pieces and cut close to line with a band saw. The cut offs are used to make bending form and spreaders. I then screw the MDF pattern to one piece and route it on the router table using a 2" spiral bit with bottom bearing. Then I take off the MDF pattern and screw another over cut plywood blank to plywood finished piece and use it as the pattern. Then I'll just keep stacking them as I go and flipping them over as I add. That way I can route a 3" thick mold with a 2" cutter and when I'm done it's screwed together and no need to glue or you can put glue on it before you screw the pieces together. It's a pretty fast process. I'd rather buy a plexi body template and make the exact molds and forms from that using the inlay kit. I did a tutorial on How I do my molds and forms over at MIMF but it's in the library limbo. Another future youtube I guess when I decide to build another style of guitar.
