It is currently Thu Aug 14, 2025 7:29 am
 Post subject: Truss rod question
PostPosted: Thu Apr 30, 2009 11:02 am
First name: David
Last Name: Willoughby
City: Raytown
State: Mo.
Zip/Postal Code: 64138
Hello, fellow guitar lovers. This is my first posting in this forum. I just recently developed a passion for building guitars, electric right now and accoustic later. I have about three decades of pro experience in the custom cabinetry and woodworking field, so I'm going into this with confidence and a focused mind on the challenges to precise milling and fitting. I am privilaged to be able to build in the shop where I work. My employer is quite interested since this personal project is other than a cabinet or piece of furniture.
I am planning to use StewMac's HotRod and it calls for a pretty deep groove. The neck's thickness w/o fret board will be 9/16" at first fret and taper to about 3/4" in the 12th to 15th fret area. Would there be a problem with a 1/16" deep groove in the fretboard to allow a shallower grove in the neck? Thanks.
 Post subject: Re: Truss rod question
PostPosted: Thu Apr 30, 2009 11:24 am
It may make it a bit harder to remove the fingerboard for repairs later. Other than that, it works fine.
http://www.chassonguitars.com
PostPosted: Thu Apr 30, 2009 2:08 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
J.D.
Go for it !!
Nice idea !
Some of us will use it also .
I see no problem removing the f.b.
Mike Collins
PostPosted: Thu Apr 30, 2009 2:47 pm
Why not just choose rod that is less obtrusive and unnecessarily tall?
I love a lot of things StewMac creates and offers, but the hot rod is a particular piece where I just see absolutely no redeeming values, or qualities that place it equal to or above the alternative designs. In other words, I can't think of a single good reason to choose it.
Check out Allied Lutherie's new rod. It's a brilliantly simple design. Rather than a reverse thread on one side, there is simply a course thread on one end and a fine thread on the other. The reverse thread design with the 10-32 threads effectively end up as though you are tightening a rod with a 16 thread. Not great in my opinion and experience. By using a 24 thread at one end and a 32 at the other, Mark Blanchard's design at Allied gives the equivalent of a 128 thread, or a standard 32 thread through a 4:1 gear box if that's easier to picture. Perhaps a little more geared down than I would prefer (I like some feedback in the form of torque when I'm adjusting a rod), but if I had to choose between the equivalent of a 16 thread and a 128, I'd personally choose the latter.
Or if you don't want the overly smooth turn, LMI's rod is the same design but with the reverse thread / courser adjustment. Either way, they both work as well as the Hot Rod, but are 1/16" shallower. The choice seems a no-brainer to me. Of course, opinions and experiences will vary. I've personally repaired at least a half dozen necks from various builders in which the Hot Rod split through the back. Just unnecessary depth with no advantage in my opinion.
PostPosted: Thu Apr 30, 2009 2:51 pm
I'm with David. Both the LMI and Allied rods are great.
PostPosted: Thu Apr 30, 2009 2:58 pm
First name: David
City: Raytown
State: Mo.
Thanks, Mr. Collins, I appreciate experienced opinion. I delve into this humbly and willing to learn and unlearn.
PostPosted: Thu Apr 30, 2009 4:47 pm
First name: David
City: Raytown
State: Mo.
Mike Collins wrote:
J.D.
Go for it !!
Nice idea !
I would recommend making the groove in the fret board a little wider than the one in the neck, though. On second thought, from a novice mind you, could one use a slightly raised truss rod to help align the fret board during glue up if the groove in it matched the neck's?
PostPosted: Thu Apr 30, 2009 6:45 pm
I've done something similar using 1/4" carbon fiber tubes half in the neck and half in the fretboard. Does very well to align everything when gluing but I don't think I would try to do that with a truss rod.
Users browsing this forum: Doug Moore and 13 guests
