It is currently Mon Aug 18, 2025 12:31 pm
 Post subject: Dry sanding tip
PostPosted: Sat May 02, 2009 9:24 pm
First name: Jeff
Last Name: Hewitt
Zip/Postal Code: 37312
I run across these sanding disc at a local auto parts store. They are called " 3M Trizact disc". They only come in three different grits. 800-1000-3000. I've only used the 1000 grit with the hook and loop holder on the drill. The cool thing about these disc is that the disc do not gum up or load up while dry sanding. After 10 or 15 seconds of sanding I just used compressed air to blow the dust off of the disc. It was clean and just like new again. They also seem to be durable and not just a one time use only.
Just had to share....I thought it was amazing there was no load up!!
 Post subject: Re: Dry sanding tip
PostPosted: Sun May 03, 2009 6:13 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Be careful. If you're using an air powered die grinder those little disks can remove alot of material real quick.
PostPosted: Sun May 03, 2009 6:46 am
First name: Jeff
Last Name: Hewitt
Its an electric close quarter drill.......running at low rpm
Users browsing this forum: DennisK and 6 guests
