It is currently Wed Jul 23, 2025 1:17 am
 Post subject: which grits?
PostPosted: Wed May 20, 2009 6:40 am
What grits of sand paper do you run on your twin drum sander, for sanding top and back plates? thanks Jody
 Post subject: Re: which grits?
PostPosted: Wed May 20, 2009 8:20 am
I have 80 and 120/150, although i usually have it set up to only use one drum at a time. I go for 60 grit if there is a lot of material to hog off.
Jordan Aceto
Ithaca, NY
PostPosted: Wed May 20, 2009 9:02 am
Same here.
Randy Muth
RS Muth Guitars Website
RS Muth Guitars Blog
Facebook Fan Page
PostPosted: Wed May 20, 2009 9:11 am
I load mine with 100/120 or 120/150. I prefer the higher grits as I find the lower ones leave me with too much sanding afterwards.
A drum sander is not a planer and shouldn't be used as such. If I have a lot of material to take off, I just take more passes. A good planer is on my 'goodies I want' list...
Anyways, if you try to take off too much material at once, you'll clog up your paper, regardless of grit.
PostPosted: Wed May 20, 2009 4:31 pm
cool , thanks Guys! jody
