It is currently Mon Jul 21, 2025 11:29 am
 Post subject: Pores Again
PostPosted: Wed May 20, 2009 10:20 am
I pore filled my current build with Stew-Macs Color Tone clear pore filler and didn't do as god as a job as I thought. After the first six coats of Nitro and sanding, I'm seeing quite a few pores that won't be filled with lacquer any time soon. What's the best way to fill these? I was thinking of trying CA over the lacquer after allowing it to cure for two weeks. Is that a waste of time? Would it be better to strip the lacquer and start over?
 Post subject: Re: Pores Again
PostPosted: Wed May 20, 2009 10:41 am
No, do not put CA over the lacquer. That would be a mess.
I would try sanding the lacquer down and applying more coats. The pores should fill with the lacquer eventually.
PostPosted: Wed May 20, 2009 11:06 am
Thanks Barry,
I think I'll drop fill the 5 or 6 big ones and then continue with the lacquer.
PostPosted: Wed May 20, 2009 11:17 am
Even with no pore filler at all, 8-10 coats of lac will be enough to fill them once you sand back. Then add another 5-6 and let cure.
PostPosted: Wed May 20, 2009 11:37 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
If there's only 5 or 6 big ones just drop fill them with lacquer. I'm pretty good at pore filling but I've always had a few places to drop fill in between coats.
Users browsing this forum: Bing [Bot], Colin North and 32 guests
