It is currently Mon Aug 18, 2025 4:05 am
PostPosted: Fri May 29, 2009 3:11 pm
First name: Lars
Last Name: Stahl
City: Stockholm
Country: Sweden
Ok so I had a bearclaw top that was just screaming Brace me. So I did.
Needs some final sanding and cleaning up, but other than that I am done. feel free to give me critique. this is the second I am doing with lattice beneath the main x. the first sounds super so I thought I should make another this way. this top is Bearclaw sitka from alaskan spruce. looks great, but the tone is not as nice as the german I had for my latest but it rings ok, it has a little shorter ring and more "ping" to it than the german.
Lars.
PostPosted: Fri May 29, 2009 4:26 pm
Country: Romania
So the Sitka is heavier than the German (as it would be expected). That exact same German (I have some sets from the same tree, they weight about 430Kg/m3) sounds shorter and pingier than a lighter than usual Swiss top (400Kg, slightly off quarter cut making it a little floppy across the grain and bassy sounding) i used on my forth :)
Other than that, the braces look nice. Although, what thickness is the bridge plate?
Build log
PostPosted: Fri May 29, 2009 6:09 pm
First name: Lars
Last Name: Stahl
City: Stockholm
Country: Sweden
Thanks Alexandru. The bridgeplates thickness is 3mm. So did you like the wood from German spruce ? .
Lars
PostPosted: Fri May 29, 2009 10:09 pm
Last Name: Hodge
Love it Lars thanks for sharing. Have a great weekend! [:Y:]
Bill Hodge
PostPosted: Sat May 30, 2009 12:36 am
You sure are busy. You must have the bug. :)
PostPosted: Sat May 30, 2009 3:40 am
First name: Lars
Last Name: Stahl
City: Stockholm
Country: Sweden
Yes I´ve been biten. :D :D .
