It is currently Wed Aug 06, 2025 10:12 am
PostPosted: Tue Jul 28, 2009 12:32 pm
First name: Corky
Last Name: Long
City: Mount Kisco
I've been experimenting with different pore fillers. Currently working with Zpoxy on a Koa 000 sized that I'm building. One thing that I've noticed is that it is much darker than the System 3 that I used last. It seems to make the Koa much darker (and darker than the Koa appears with a bit of Naptha on it.
How careful do I have to be to make sure I sand it all back from the wood (and not the pores, of course)??
One note - I'm not using the Zpoxy on the top - just the back, sides and ncek.
Is there ever an issue with a "blotchy look" if I am less than successful in uniformly sanding the porefiller back before finishing (with KTM 9 in this case.)
Thanks.
PostPosted: Tue Jul 28, 2009 3:10 pm
Some people like to leave a layer of Zpoxy, or rather add a diluted layer of epoxy, after the pore filling is done. As you have noticed, Zpoxy has a yellowish hue, which is one reason this is done as some find it attractive. As an added bonus the epoxy will make the wood look "deeper", or give it a "wetter" look than almost any finish, at least more than waterborne finishes. I like to sand back to bare wood, and find that nitro or shellac gives much of the same wet look. And yes, there is definitely a danger that the wood will look blotchy if you don't sand uniformly back to bare wood.
PostPosted: Tue Jul 28, 2009 5:40 pm
PostPosted: Thu Jul 30, 2009 9:09 am
First name: Corky
Last Name: Long
City: Mount Kisco
Thanks for the replies - helpful.
I like shellac, so how about this for a process. After completing prep work, and sanding down uniformly (220 fine enough?) Wipe with a coat of dewaxed shellac. Then, after dry, apply a thin coat of Zpoxy - let dry overnight, then sand back to the wood. Zpoxy again, sand back again. One more coat of shellac, then KTM 9. Unnecessarily complicated? My reasoning is that if I mistakenly cut through the shellac to the bare wood, the last shellac coat before the KTM 9 will give it a uniform appearance.
One followon question. The Zpoxy finishing resin that I am using has a darker than "yellowish" tone to it - I"d describe it as almost a light cranbury color. I've been careful to mix it 50/50 with the hardener which is what gives it the color. Are we talkoing about the same stuff?
PostPosted: Thu Jul 30, 2009 9:19 am
Corky,
Do a test to make sure that the z-poxy will stick/cure to shellac. I have not used z-poxy but I don't think the west systems I have been using will work over shellac. I have been thinking about doing the same thing you are proposing but with waterlox as the seal coat. I still have to make sure the westsystems will stick to that too. Whenever I sand back to bare wood I expose a pore or two and with any finish that sinks at all, it will eventually telegraph through. Not the end of the world, of course, but nice to able to avoid.
Burton
Brookline, MA.
