It is currently Fri Aug 15, 2025 6:37 am
 Post subject: cf neck rods oops
PostPosted: Mon Apr 05, 2010 9:21 pm
Yesterday, I installed my first CF rods in a neck. Today, I went downstairs, looked at it and remembered I should have cut them short enough to clear the tenon cheeks, but I didn't. When I go to cut the tenon, will my router bit go through those at all, or should I cut it close and get in there with the hack saw? Could I make the tenon really wide for the top half inch? Other option? Either way, it won't be too soon. I need to finish my jig and templates.
If it matters, it's Los Alamos rectangular rod.
Mike Lindstrom
 Post subject: Re: cf neck rods oops
PostPosted: Mon Apr 05, 2010 10:04 pm
Mike,
You can cut them with your router, but you'll ruin your bit doing it. Even if you cut them close with a hacksaw you'll probably still ruin your bit.
PostPosted: Mon Apr 05, 2010 10:33 pm
Thanks, Jim. I figured it would ruin the bit whether it cut the CF or not. I am wondering if I can route around it and then relieve the shoulders ala Hesh's neck fitting tute, giving me access to undercut with the hacksaw. We'll see how it goes. As long as I stick with an opaque fretboard on this one, it should end up fine.
Mike Lindstrom
PostPosted: Tue Apr 06, 2010 12:48 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I did the same thing, first time... Bad word! Bad word!
I trimmed the stubs away with a cutting wheel chucked in the Dremel tool. Only after dulling my favourite chisel... Twice!
It's worth having a Dremel mandrel & a few of the cutting discs around... Very handy for fixing little screw-ups.
PostPosted: Tue Apr 06, 2010 6:52 am
Thanks Daniel. I don't have a Dremel, but my friend uses his for everything. I'll make sure I borrow it.
Mike Lindstrom
PostPosted: Tue Apr 06, 2010 8:57 am
First name: Tom
Last Name: West
City: Williamswood
State: Nova Scotia
Mike: Any chance of incorporating the CF in the tenon by making it wider...? I put my rods close to the truss rod slot and let them run out to the end of the tenon.
Tom
PostPosted: Tue Apr 06, 2010 12:06 pm
CF rod too long here, too.
Chuck a roto-zip 1/8" ceramic tile cutting bit into your Dremel - cheaper than the Dremel bit. With Dremel in SM router base, pivot the bit into the CF rod - in my case, both 1/8" - using the continuous edge of the router base as the pivot point.
I rev'ed up the Dremel and lowered slowly.
Repeat as necessary.
Nothing but a tiny pile of CF dust. Vacuum it up.
Wear a mask.
Couldn't be easier.
