It is currently Sat Sep 20, 2025 7:14 pm
PostPosted: Wed Nov 03, 2010 9:12 am
Ok, any tips for getting errant CA (don't ask! :shock: ) off a polyester finish? The way I would approach it would be to scrape almost down to the surface finish with a razor blade, the progressively wet sand and buff...but I really don't want to...any easier way to just get the CA and leave the finish undisturbed?
PostPosted: Wed Nov 03, 2010 9:41 am
You may want to double check (read "test under a tuner"), but I believe acetone will desolve CA but not polyester. IIRC, Rick Turner finishes his guitars with polyester and glues his bridges with CA, cleaning the squeezout with acetone.
Alain Moisan
(Now building just for fun!)
Nitromethane is a CA solvent. You can probably get a small bit at your local speed shop.
Jim Womack
Will Rogers
PostPosted: Wed Nov 03, 2010 10:27 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Acetone will work fine.
PostPosted: Wed Nov 03, 2010 11:44 am
I know acetone is supposed to remove CA, but the times I have tried it didn't work worth a flip, guess I need to try a product specifically designed to remove it....maybe I'll try the Nitromethane.
Greg
Gwaltney Guitars
PostPosted: Wed Nov 03, 2010 1:10 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Nitromethane is more explosive than dymanite. Be careful messing with it.
PostPosted: Wed Nov 03, 2010 3:40 pm
Acetone will work just fine. If the CA is dry, you may have to rub an acetone wetted cloth a little in order to allow the acetone to loosen the CA. If the CA is a fresh spill, the acetone will work very quickly.
jw ( o)===:::
PostPosted: Wed Nov 03, 2010 4:58 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
well then, if she blows, that should knock the lump of CA right off.
PostPosted: Wed Nov 03, 2010 7:12 pm
Last Name: Garrish
It helps if you can keep the CA submerged in acetone. If you can make a little dam around it with something acetone-proof and put a cover over it so that the acetone doesn't gas off, then a little patience is all it takes.
Bob Garrish
PostPosted: Wed Nov 03, 2010 7:30 pm
I guess nitromethane is more energetic than TNT, but it's not so easy to get it to explode. It is used all the time as a solvent in the lab and in industry. I'm not sure what the "Super Solvent" that StewMac sells is, but it works quite a bit better than pure acetone. My guess is that it might be a mixture of solvents, perhaps containing nitromethane as well. I've never tried straight nitromethane and would be curious to know how well it works from someone who has.
Randy Muth
RS Muth Guitars Website
RS Muth Guitars Blog
Facebook Fan Page
PostPosted: Thu Nov 04, 2010 7:59 am
Ok, thanks guys! [:Y:]
PostPosted: Thu Nov 04, 2010 12:04 pm
I started using CA (Hot Stuff) back in the early 70's on competition free flight models. There was no available commercial debonder then, so we used nitromethane. We mixed our own fuel so we had a bit of it around. It works much better than acetone. It's really no more dangerous in small quantities than any thing else we have in the shop... lacquer thinner, denatured alchohol, acetone, etc.
All the commercial CA debonders that I'm aware of contain nitromethane or nitroethane with additives to control evaporation.
Jim Womack
Will Rogers
PostPosted: Thu Nov 04, 2010 2:49 pm
And ..ah... Lar! Next time you're playing with the CA ...don't pick your nose! [:Y:]
PostPosted: Thu Nov 04, 2010 3:14 pm
Thanks Jim, I use to have free access to nitromethane when I worked as a chemist. Unfortunately, now I don't.
Randy Muth
Facebook Fan Page
Users browsing this forum: DennisK and 35 guests
