It is currently Mon Jul 28, 2025 8:56 pm
 Post subject: Gearing up question.
PostPosted: Sat Jan 08, 2011 7:41 am
Last Name: Tulloch
State: Vermont
I've built two guitars in the last 3 years....and want to set up better in the shop to maybe do 3 in the next year. One area at the front of it all is the air compressor issue. Firstly my little pancake job won't run the Sioux pencil die grinder inlay router I use for the inlay (never shuts off). And I've been sending out to get the finishes done by a pro....I'm thinking I want the compressor to also serve the eventual / hopefull spray system, should I jump in that pond. For the inlay, I would like to be able to run 2 routers at a time ...with the regulated air blower lines to disperse chips during the rout.
There's the $450. single stage 60 gal. thing at Home Depot at the lower end of things...and up from there into the bigger tanks and 2 stage configurations for higher bucks. Money is an issue...but it has to be the good stuff.
I can sort it all out by comparing specs / needs, name brand ...usual method , then hope for the best, or.....
Some input from those who have been here before, would be greatly appreciated.
Michael
 Post subject: Re: Gearing up question.
PostPosted: Sat Jan 08, 2011 8:41 am
Hi Michael
Personally I would go with a reciprocating compressor (piston style) as I think you will find they are much quieter than the alternative. You don't need a really large one to spray but your air router may need a fair amount of CFM so be sure to check it's needs before.
PostPosted: Sat Jan 08, 2011 8:59 am
Last Name: Tulloch
State: Vermont
Thanks John....piston type for sure....would like to hear also..what sort of compressor you use personally in your shop . Name and model if you don't mind.
PostPosted: Sat Jan 08, 2011 9:17 am
If you will be doing your own finishing, it's not so much the compressor for spraying as the air powered D/A sander. I got along very well with a 20 gal compressor for spraying, but when wet sanding the finish I went to a 60 gal, which is barely enough. Were I to do it again, I would probably go 80 gal.
PostPosted: Sat Jan 08, 2011 10:36 am
Last Name: Tulloch
State: Vermont
Thanks Hans....80 Gal. Air powered DA. sander...right.
Any thoughts as to single stage...2 stage.? I understand the 2 stage best serves higher pressure needs....but to the Luthier?
Campbell Hausfield ...good stuff? Or.?
PostPosted: Sat Jan 08, 2011 12:42 pm
Mine is an old 20 gallon Campbell Hausfeld don't know the model but single stage. It does the trick for spraying and blowing dust around but would definitely not power a orbital sander. I use an electric or sand by hand so not an issue with me. I almost bought a larger one last year because I was thinking of trying an air orbital but decided I didn't want to spend the money for a big noisemaker in the shop. I suppose I could move it out of the shop and build it it's own little house but that would just be a place for spiders and bees to call home. Guess I'll just wait till it gives up the ghost. It is over 20 years old though so I guess I would recommend their stuff.
PostPosted: Sat Jan 08, 2011 12:47 pm
This may be a naïve question but is there any advantage to an air powered orbital sander compared to an electric one?
PostPosted: Sat Jan 08, 2011 12:48 pm
Last Name: Tulloch
State: Vermont
Good question......
PostPosted: Sat Jan 08, 2011 12:58 pm
B66, I have a 20 gal DeVillbis for spraying and a Campbell Hausfield 60 gal for D/A. Both are single cylinder.
Charlie, you can't wet sand with an electric!
PostPosted: Sat Jan 08, 2011 1:00 pm
When I was looking into it I was planning to do wet finish sanding with the orbital so I wanted air versus electric. I decided to continue sanding by hand.
PostPosted: Sat Jan 08, 2011 1:19 pm
Ah...I take it electricity and and water don't play well together. duh :D
Addam Stark wet sands with an electric. He's been a professional guitar finisher for many many years.....
Here's a picture of him off his facebook page.
It's not like you are immersing the sander in a bathtub. Of course one needs to be careful, but you CAN wet sand with an electric!
PostPosted: Sat Jan 08, 2011 1:22 pm
Adam Stark wet sands with an electric. He's been a professional guitar finisher for many many years.....
Yes you can and I have done it myself but I did not have a groovy feeling while doing it!
PostPosted: Sat Jan 08, 2011 1:44 pm
Last Name: Tulloch
State: Vermont
...groovy feeling.....that a California thing? 8-)
Being a hands on guy for soooo long....probably won't need an air sander at this stage. But the air routers and finish spray are primary. Sounds like a 60 Gal. single stage will do it.
This is the HD unit:http://www.homedepot.com/Tools-Hardware-Air-Compressors-Tools-Accessories-Stationary-Compressors/h_d1/N-5yc1vZ1xn8Zbb2r/R-202043183/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
PostPosted: Sat Jan 08, 2011 3:05 pm
I've also wet sanded with electrics many many times without issue. It's just a thin film on the surface. The air sanders are way easier to control as you have variable speed available on the fly...Sorry that don't help you OP...
PostPosted: Sat Jan 08, 2011 4:18 pm
Looks like a good way to get buzzed...
Hey, I used to spray spirit varnish through a window fan too!
PostPosted: Sat Jan 08, 2011 7:20 pm
Last Name: Tulloch
State: Vermont
Actually medfool...your replys do help...as I'm working through all this, and thinking about each suggestion.
Thank you all.
