It is currently Tue Jul 29, 2025 2:56 pm
PostPosted: Thu Jan 13, 2011 9:38 pm
FWIW I have been able to find that stuff locally at a place called Main Sheet Metal. It's been a long time since I ordered a piece cut but they always had it in stock, whatever size you want they charge by square foot plus number of cuts, plus I think a small charge to smooth the edges out so it isn't deadly. Maybe keep calling sheet metal or general metal working shops...
Filippo,
Check McMaster Carr http://www.mcmaster.com/#catalog/116/405/=akvjd0
Wider than you want but a sheet metal shop could shear it for you. You could probably even sell the extra here.
PostPosted: Fri Jan 14, 2011 1:19 pm
Go to McNichols.com and reference item 1820433026. It comes in 19" widths @ 30 gauge.
PostPosted: Fri Jan 14, 2011 1:48 pm
or try a local sheet metal fabricator/shop
PostPosted: Fri Jan 14, 2011 7:23 pm
I use the Doolin style bender, but gave up on the perforated stainless. It works fine without, just don't wet the wood very much. Don't need to anyway.
Randy Muth
RS Muth Guitars Website
RS Muth Guitars Blog
Facebook Fan Page
PostPosted: Fri Jan 14, 2011 8:13 pm
I used perforated SS in the beginning, but didn't like it. It took too much of a set, esp. for a cutaway. I don't remember what gauge it was or where I got it, but it was the thinnest I could find.
Randy Muth
Facebook Fan Page
PostPosted: Fri Jan 14, 2011 8:42 pm
I just went through my records. The stuff I had was 26 gauge (0.18") from McMaster.
Randy Muth
Facebook Fan Page
PostPosted: Fri Jan 14, 2011 9:48 pm
What you building Filippo? The Doolin style bending jig? If so, just so you know, I don't use perferated plate or SS, I'm just using spring steel and have no issues.
I know we often give information without being asked for it, so I'm just staying the coarse ;)
So, care to share what you're building.... :D
