It is currently Tue Jul 29, 2025 3:03 am
PostPosted: Thu Jan 13, 2011 5:38 pm
First name: Sondre
Country: Norway
When thicknessing the back on my current build, I noticed some yellow discoloring starting to appear in the sapwood. Does anyone know what it is and how long it takes before it disappears? The white-balance is a bit off on the pic, but the stuff has a really intense, lemonish yellow color. You can see it on the cut-off on the pic, but not on the actual back. Thanks!
PostPosted: Thu Jan 13, 2011 8:10 pm
Character :D
I like little things like that that show its a natural material. As long as it dosnt affect the stability of the wood. Someone may have a better answer.
PostPosted: Thu Jan 13, 2011 8:15 pm
It's wood. I like the inconsistencies as long as there are no structural concerns, which it doesn't appear to be in your case.
PostPosted: Thu Jan 13, 2011 9:32 pm
First name: Randolph
Last Name: Morris
Sondre, I couldn't say for sure if this color is a stain from something the tree sucked up and is permanent or not. It isn't uncommon for wood that is not completely dry to exhibit a yellowish color until it dries. Could this stuff be a bit green still?
PostPosted: Fri Jan 14, 2011 12:07 pm
First name: Sondre
Country: Norway
Nothing wrong with character :). It's just that the color is so intense it looks completely unnatural. And it looks bad around the center seam since the stuff appears to have occurred at random...
The set has been drying in my shop for at least a year now. I guess I'll just wait and see.... Thanks guys
PostPosted: Fri Jan 14, 2011 1:02 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Staining in sapwood is quite common. As long as there is no decay, it should be fine structurally. If you don't like the appearance, you can always dye it.
