It is currently Mon Aug 18, 2025 1:37 pm
PostPosted: Tue Jan 18, 2011 3:49 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I just finished fretting an acoustic nylon folk guitar with a 14 ft radius . Some of the frets are high , bowed etc. This is an older fretwire that seems soft and does not have any barbs. the tang is 1.5 mm deep and about .021 thickness. I would also like to use this fretwire ( sorry no photos0 to refret an old harmony archtop, rebuilt with an osage orange fingerboard. My question is , what techniques do you use for bending the fretwire to the correct radii. I have been using a 12 oz plastic hammer . I have seen fret bending tools on e - bay . Your suggestions and opinions would be appreciated
PostPosted: Tue Jan 18, 2011 5:52 pm
First name: Sondre
Country: Norway
I just make one convex and one concave hardwood block with the appropriate radius. Then I cut a slot for the tang in the convex block, place the fret in the slot and squeeze the blocks together. Simple, but it works for me
PostPosted: Tue Jan 18, 2011 6:48 pm
Soft and no barbs, sounds like a receipe for difficult installation and early wear.
Good fretwire is cheap, using this seems like false economy.
PostPosted: Wed Jan 19, 2011 1:29 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I just bend it by hand with the tang pressing into my thumbs and use all fingers to bend. Seems to work well for me and I get a nice smooth bend with a couple passes. I bend the whole strip before cutting.
I over bend it slightly so the ends of the fret touch the fingerboard and the middle is a few thousandths high
PostPosted: Wed Jan 19, 2011 1:48 pm
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
The old bar fret material came with no barbs. Installers would sometimes hammer a bunch of V shaped dents into the tang side of the bar every half inch or so. With a hammer kind of like a rock hound hammer. The V's would spread out a little and act as barbs to hold the fret in the wood.
Give that a try or buy some tanged fret wire.
PostPosted: Wed Jan 19, 2011 9:34 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
thanks everyone for the input.
