It is currently Sat Sep 13, 2025 4:03 am
PostPosted: Sat Feb 19, 2011 11:59 am
First name: David
Last Name: Hurd
City: Placerville
Zip/Postal Code: 95667
http://www.caswellplating.com/buffs/wood_pol.html
I am going to order this. I'll let you know what I think. Caswell also sells arbor shaft extender kits for $11 per side. Extends each arbor by 6 1/2".
PostPosted: Sat Feb 19, 2011 1:17 pm
I have it and the machine is good. But I think the buffs are not what works, cause as is I cab't polish nuttin even with the Menzerna compounds. But that's the wheels, not the machine. Others use it successfully. Good to know of the arbor extenders.
PostPosted: Sat Feb 19, 2011 1:39 pm
First name: David
Last Name: Hurd
City: Placerville
Meddling
Thanks for the comments on the buffs. Any recommendations in that regard?
PostPosted: Sat Feb 19, 2011 1:49 pm
Thanks Dave. I've thought about that machine. Didn't know about the longer shafts.
Grizzly buffs are doing fine for me. The softest, which I think is domet.
[edit] I found the shaft extenders. Not as heavy duty looking as I thought; I had hope you could just get a longer 3/4" shaft on the machine. The big buffs have larger than 1/2" holes and will need adaptors. Not a huge deal, but the ones I made (for the ShopFox) have a way of working loose.
PostPosted: Sat Feb 19, 2011 2:03 pm
I use the grizzly shop fox buffing set up with 1/4 hp. This is plenty of power .
PostPosted: Sat Feb 19, 2011 2:33 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
That's the buffing machine I use. I didn't buy the kit, just the buffer. I use buffing wheels from Grizzly. The shafts seem long enough to me, but I'm used to them.
