It is currently Sun Aug 17, 2025 6:52 pm
 Post subject: Uke top
PostPosted: Sun Feb 27, 2011 4:52 pm
I'm considering using an old flamed mahogany back I have as a tenor ukulele top. This will be my first foray into the ukulele world, so I'm unsure if the top thickness will be sufficient (It's about .080). If it's too thin, I'll probably buy a koa top, but the mahogany is exceedingly well flamed, and would make a beautiful uke. Any thoughts?
Jimmy Caldwell
 Post subject: Re: Uke top
PostPosted: Sun Feb 27, 2011 7:12 pm
That is not too thin for a uke top.
Ken Franklin
clumsy yet persistent
PostPosted: Sun Feb 27, 2011 8:55 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Hi .075 -.080 will work depending on your back and sides , a double side 2 thin pieces .045 will make a very stiff and rigid side. For more info on ukes check out my videos http://www.ateliertomi.com
PostPosted: Mon Feb 28, 2011 1:31 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
0.08 should be ok. Just be really careful with sanding. You'll probably want a sound hole patch if you do a rosette.
Users browsing this forum: Chris Ide, peter.coombe and 11 guests
