It is currently Wed Aug 06, 2025 11:08 pm
PostPosted: Wed Mar 02, 2011 4:51 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I've been sitting on this Bubinga board for about 5 years now. I bought it before I had any interest in guitar building because it's a unique board.
It measures 8" X 41" & it's 1-1/2" thick. Big enough for a couple of OM's.
My concern is that it's pretty much flat sawn. I've never had good luck resawing flat sawn - it always curls up or cups as it dries. I'm also worried about trying to bend flat sawn wood.
What would you do?
Kevin Looker
I'm not a luthier.
PostPosted: Wed Mar 02, 2011 4:55 pm
Make a jewelry box for the wife...
PostPosted: Wed Mar 02, 2011 4:58 pm
First name: Big
Last Name: Jim
I have two really great ideas , ( 1 ) Build an Electric . Or ( 2 ) Send the wood to me and I will make sure it stays safe for you ! laughing6-hehe laughing6-hehe
PostPosted: Wed Mar 02, 2011 6:18 pm
That would so powerfully tempt me, that I probably would not be able to resist trying to build with it.
What you could do is try slicing up half of it, sticker/weight that, and see how it behaves. If you can't build out of it, you've got lotsa beautiful bindings/ headplates at the ready.
Or, jewelry box material for sure.
Or neck stringers,
Or....
PostPosted: Wed Mar 02, 2011 6:24 pm
Send it to Borson Resaw and he'll get you the most yield possible.
You can always double the sides if concerned. I would build with it in a heart beat!
PostPosted: Wed Mar 02, 2011 6:30 pm
One of my students is building with something very similar right now .. it bends fine, easier than waterfall, doesnt facet either.
I cut mine up myself about 4-5 years ago, it stayed flat .. yours might even be from the same tree, who knows ... There is easily two sets in there.
PostPosted: Wed Mar 02, 2011 6:34 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I am going to offer a radical idea. Because I think you will, as you suspect, have a heck of a time getting it to stabilize, if ever. Cut it into strips 5/4 thick. Rotate them 90 deg to glue. Of course, joint the edges (thus the 5/4). Resaw. Not sure if the glue would survive the bending, though I am sure I have see guitars built like this.
Or, use for electrics. Or use bridges and other stuff.
I wonder how much I will get hammered for that suggestion? ;)
PostPosted: Wed Mar 02, 2011 6:56 pm
I'd build a birdhouse or cigar box with it, cut the rest into sticker strips for wood drying.
Old growth, shmold growth!
PostPosted: Wed Mar 02, 2011 9:09 pm
Hi Kevin,
If you had this board for 5 years, it's pretty dry as far as I'm concern. Go ahead and resaw it and use it for your two OMs.
If you bend with a Fox type bender, I wouldn't worry about bending.
I've build with bubinga just as flat sawn as this one, by the way.
This wood is far too pretty to not make a guitar with it!
Alain Moisan
(Now building just for fun!)
PostPosted: Thu Mar 03, 2011 2:15 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I agree. The only provision I would make is to warm up the back for an hour or so just before bracing it.
PostPosted: Thu Mar 03, 2011 2:42 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Thanks for all the replies & encouragement. I hadn't thought about bindings, brige plates etc. if it doesn't work out.
Nothing ventured...
I just ordered a new woodslicer bandsaw blade. Unfortunately, I need a custom length so it will take about 6 weeks.
Kevin Looker
I'm not a luthier.
PostPosted: Fri Mar 04, 2011 7:48 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
If I could just talk my wife into allowing me to turn this board into a bunch of guitars. [:Y:]
PostPosted: Fri Mar 04, 2011 10:06 pm
Beautiful piece Kevin. Good luck cutting bubinga with a Woodslicer. I never had any luck.
PostPosted: Sat Mar 05, 2011 12:11 am
Last Name: Forbes
City: Gilbert
State: Arizona
Zip/Postal Code: 85297
It's funny how instrument makers see a beautiful table and think of it in terms of how many guitars they can get out of it. I think that you should take that table and re-saw it into back/side sets anyway. I mean, a table that nice, you want to protect it from getting coffee stains or scratches on it...the best way to do that is to get a cheaper table and make guitars out of that one.
And something on topic...I would make a guitar out of that piece. It's dry, take time on the bending and maybe leave the sides a bit thicker to avoid cracking them, but soak them much longer so they get wet all the way through right before you bend. I always find my second piece of wood bends far nicer than my first, and I think it's because it spent an extra 20 minutes in the bath.
http://www.sixgunguitars.com
PostPosted: Sat Mar 05, 2011 12:17 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Bob,
Thanks for the input. I value your opinion.
What type of blade do you prefer for bubinga? I've been using a 1/2" X 4tpi Lenox skip tooth blade with good results in Padauk, Sapele (butter), Wenge and Ovangkol. I've only resawn bubinga once before & it was many years ago. I remember it being very hard but I don't remember it being oily which seems to cause more trouble as it cakes up on the blade.
I haven't used the woodslicer but I guess I've been taken in by the marketing and the 1/32" kerf.
Kevin Looker
I'm not a luthier.
PostPosted: Sat Mar 05, 2011 12:56 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I am not sure what blade Bob will suggest, but I would have no fear attacking it with a Resaw King blade from Laguna. Look at the Borsin videos. Mounting the board to a stable back board will keep the board from moving as you slice it.
Let us know how it goes!
PostPosted: Sat Mar 05, 2011 8:49 pm
As Todd suggests carbon steel should get you through that board. Ovankol is similar to bubinga so you should be fine. Another nice blade is the Lenox bi-metal. I don't want to recommend carbide as the cost is quite high for occasional re-sawing. Easy to cut? Not in my opinion. I think of woods like mahog, walnut, cherry, oak, IRW, etc. as easy to cut. Bubinga is hard stuff. I really don't know why people don't use it more often. It's a great tonewood.
PostPosted: Sat Mar 05, 2011 10:37 pm
Last Name: Peck
City: Templeton
Zip/Postal Code: 93465
The RewsawKing blade cuts Bubinga without any trouble. If you want to see Bubinga being sliced in our shop watch this video...
https://www.facebook.com/video/video.ph ... 4&comments
Lance Peck
PostPosted: Sat Mar 05, 2011 11:36 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
I'd love to try a Resaw King but it would set me back about $400 wow7-eyes
The carbon steel Lenox & Starrett blades I've been using work pretty well when they're fresh & sharp and they're roughly $30. I'll stick with them for now.
Thanks for all the replies.
Kevin Looker
I'm not a luthier.
PostPosted: Sun Mar 06, 2011 12:38 am
Nice Lance. I've had problems with the re-saw king dulling very rapidly. Have they changed the blade?
PostPosted: Sun Mar 06, 2011 7:13 pm
Last Name: Peck
City: Templeton
They actually did change the blades last spring. Thinner kerf now and an actual carbide tooth created with some new German technology.
We used to have a horrible problem with the blades dulling quickly until we got the cutting technique fine tuned. They will still dull quickly if you make a mistake, but the smooth cut and thin kerf make the extra expense of the blade worth while.
Lance Peck
PostPosted: Sun Mar 06, 2011 7:18 pm
Last Name: Peck
City: Templeton
Kevin Looker
How much is one saved set of wood worth? Might not take too long to recover the $400?
But in reality if you don't have your saw set up correctly the ResawKing would not be a wise investment.
Lance Peck
PostPosted: Sun Mar 06, 2011 8:07 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Are you saying a saved set because of a reduced kerf?
The Resaw King has a kerf of 0.041 while the garden variety carbon steel blades take out about 1/16" which is 0.0215" more. After 6 slices the resaw king would save just over 1/8". In a production setting, I think the resaw king or a comparable carbide blade would be the way to go: less waste & less time spent changing blades & dialing in the saw.
For occasional resawing of mostly "common" woods or a single board of something special, I can't justify it unless I'm missing something. I will admit that most resaw mishaps I've experienced were a result of not changing the blade before it got too dull. [headinwall]
Kevin Looker
I'm not a luthier.
PostPosted: Mon Mar 07, 2011 9:23 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Kevin Looker
I know where you could get 4 Resaw King blades for that much money. I have an 18" Jet, 137" , 3/4" carbide blade and it costs me $95. Have several on the wall. All blades up to 160" are $95. PM me if u are interested.
