It is currently Mon Aug 18, 2025 5:21 am
PostPosted: Tue Apr 05, 2011 9:39 am
First name: ryan
Last Name: gerber
City: walnut creek
State: ohio
Zip/Postal Code: 44687
my first post here. i started out with a french polish on a western red cedar top, and it's the first time with the red cedar. i've spent a considerable about of time building layers with the french polish, but it still is way too easy to leave an indentation with the finger nail, especially parallel with the grain. i was a little surprised with how soft the cedar top was to begin with. so my thought was to do several coats with ktm9, which i am also using for the back and sides, to finish off the top. i've found that shellac is recommended for the sealer coat under ktm9, so my assumption is that it doesn't matter how much shellac has been built up, the ktm9 should stick just fine. am i correct in this assumption?
PostPosted: Tue Apr 05, 2011 9:49 am
City: Tucson
State: AZ
The shellac will harden over time, but you can do it the other way easy enough. Someone else can give you proper instruction and advice and perhaps think of something we haven't thought of before. If it were up to me, I'd say do another session or two of the shellac and let it harden a considerable amount of time and test it then. If you are still unsatisfied with the results, break out the KTM9
PostPosted: Tue Apr 05, 2011 10:18 am
First name: ryan
Last Name: gerber
City: walnut creek
State: ohio
i have done considerable sessions with the french polish, and it has been atleast two weeks since my last session, and it's still way too soft. what are others experience with french polish on cedar? does it require a significant increase in sessions versus a spruce top?
PostPosted: Tue Apr 05, 2011 12:10 pm
I'm not absolutely certain, but you might have a problem if your shellac isn't 100% dewaxed. I believe that that is what is called for under waterborne finishes.
PostPosted: Tue Apr 05, 2011 12:18 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
That is correct.
Also it will not work if you used any oil with your F.P.
Mike Collins
PostPosted: Tue Apr 05, 2011 2:51 pm
First name: ryan
Last Name: gerber
City: walnut creek
State: ohio
so basically it's a no go. onward i go with the french polish then. guess i'll continue to build sessions until it withstands pressure on top of the super soft cedar top. thanks for the help guys.
PostPosted: Tue Apr 05, 2011 2:56 pm
Country: Romania
Shellac is not a tough finish, probably because it is so thin in the first place. You can easily dent it between the grain even with the hardest spruce, let alone cedar....You should add more sessions until it gains sufficient visual depth and all wood features are well filled, then stop. Either way don't expect it to withstand nail or pick contacts too well, not now and not in 2 years time.
Build log
PostPosted: Tue Apr 05, 2011 5:43 pm
City: Tucson
State: AZ
On the bright side if you keep the guitar you can easily fix the finish whenever you please.
