It is currently Wed Aug 13, 2025 7:56 am
 Post subject: F-hole binding fixture
PostPosted: Tue May 03, 2011 12:27 pm
This might be of interest to some of you. I just built this simple little fixture after getting some ideas from the "bloodwood binding" thread. I wanted to laminate my binding while in it's final shape so this is what I came up with. It's just two pieces of 3/4" ply, one cut int the shape of the f hole the other is just the base. I cut notches in the corners to hold the excess binding. Dave Stewart I'm sure already did this ;)
Image. Image
PostPosted: Tue May 03, 2011 12:55 pm
First name: Big
Last Name: Jim
I like that idea , Sure glad u didnt patent it cause its offically stolen ! laughing6-hehe laughing6-hehe
PostPosted: Tue May 03, 2011 1:28 pm
I LIKE that. Consider it stolen +1
PostPosted: Tue May 03, 2011 1:51 pm
I will gladly accept donations! I meant to mention this before. The reason I used 3/4" ply is so you would have room to accomodate the arch. If you start the binding high and bend it around and down you are also "roughing in" the lateral arch. You can see what I mean in the first pic. It doesn't get it perfect but it sure gets it close.
PostPosted: Tue May 03, 2011 2:49 pm
First name: duh
Last Name: Padma
This is tempting enough for even me poor level of two left hands and a set of dentures level of craftsmanship to attempt. Thanks for posting it.
blessings
PostPosted: Wed May 04, 2011 9:08 pm
First name: Kevin
Last Name: Fultz
City: Portage
Zip/Postal Code: 49002
I'm going to make one for guitar #3! Thanks!
PostPosted: Wed May 04, 2011 10:37 pm
First name: Nelson
Last Name: Palen
Interesting setup, Jason.
Have you considered making flat patterns of the various pieces so they will "elevate" when wrapped around the form?
I do that but am using sheet material rather than precut strips of binding. The strips would be 1/4" wide or whatever required to trim flush after installing.
Nelson
PostPosted: Thu May 05, 2011 8:56 am
Nelson, I'm not sure I get what you mean. What would the flat patterns be patterns of? Also, where do you get your sheets and how do you laminate and trim them to your final dimensions? Thanks.
PostPosted: Thu May 05, 2011 9:33 am
First name: Nelson
Last Name: Palen
Jason
If you envision a piece of f-hole binding that has been glued in place and then sanded flush with the inside and outside surfaces of the top plate:
If you could unglue it and then unroll it back to it's flat state it would become a flat pattern from which more could be made.
Then, when you install them into the f-hole, they would follow the elevations around the shape of the f-hole.
I find that having the strips near net shape results in better miter joints rather than dealing with a strip that is, say, 1/2" wide before mitering.
I "cheated" by developing the flat patterns using digitizing on the CNC then cutting the flat patterns out of sheet stock.
I used to get ABS sheet from Leathertone but they sold out to another company. I can find that new company for you.
Nelson
PostPosted: Thu May 05, 2011 11:13 am
OK, I get you. That definately sounds like it would lead to less fussing when it comes to gluing them on. I've been using 1/4" binding, which is part of the reason I hate binding f-holes.....lots of fussing to get them to follow all of the many curves and not have them slide above or below the top.
PostPosted: Thu May 05, 2011 11:36 am
First name: Big
Last Name: Jim
blessings
laughing6-hehe laughing6-hehe HUH ??? laughing6-hehe laughing6-hehe
PostPosted: Thu May 05, 2011 2:52 pm
First name: Nelson
Last Name: Palen
Yeah, with 1/4" strips a person has to try bending it the hard way and that leads to less than perfect results.
I'll bet a guy could just take a 1/2" (or so) width of strip and hold it in place in the f-hole while marking the flat pattern. I've used heavy paper come to think of it.
Keep in mind that the flat pattern shortens as you add more layers of binding.
Users browsing this forum: dan2087 and 27 guests
