It is currently Wed May 13, 2026 4:13 pm
PostPosted: Thu Jun 02, 2011 7:58 pm
I just installed the extension kit to my Delta 14" band saw. Everythig was pretty easy. When I put on the new 105" blades they are too short. I tried 2.
Has this happened to anyone else here?
What can I do?
PostPosted: Thu Jun 02, 2011 8:08 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I came across an old Buffalo 14" (for $40) that is supposed to be the same as the old Delta frame. . . Somehow, it takes a 92 inch band.?. I put a riser kit on it (cost more than the saw) and have to use 104" blades. I haven't found this to be a problem since the blades I use are made to whatever length you order. I get good results on a junk saw, so if you order a 105 1/2" blade, I think you'll be really happy.
Bryan Bear PMoMC
PostPosted: Thu Jun 02, 2011 10:29 pm
Steve check the axel assembly up top. Sometimes if you don't have it tilted right it won't slide down in order for you to mount the blade. Once it's on just straighten the wheel and bring it to tension.
PostPosted: Thu Jun 02, 2011 10:30 pm
First name: Mark
City: Concord
Make sure the blade tension mechanism is not hanging up and stopping before going all the way to the bottom of the channel.
PostPosted: Fri Jun 03, 2011 9:24 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Oops, good call. I assumed that the tensioning mechanism was checked when checking the alignment of the riser and verifying the wheels are coplanar after installation. Now that I think about it (since 105 should be the right size), a problem with the tensioner is the more likely culprit.
Bryan Bear PMoMC
PostPosted: Sun Jun 05, 2011 8:12 am
First name: Big
Last Name: Jim
on my delta 14" the bolt head for the tensioner actually hit the metal housing for the wheel and would stop it from going down . I ground back a small u shaped area and the problem went away . Check that !
PostPosted: Sun Jun 05, 2011 12:58 pm
What can I do?
Measure and buy new blades?
PostPosted: Sun Jun 05, 2011 1:07 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
Newbie question: How do you measure those blades anyhow? :mrgreen:
PostPosted: Sun Jun 05, 2011 1:54 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I had the exact same problem - early 90's model that was still USA made.
Kevin Looker
I'm not a luthier.
PostPosted: Sun Jun 05, 2011 5:02 pm
multiple post
Last edited by Howard Klepper on Sun Jun 05, 2011 5:04 pm, edited 1 time in total.
PostPosted: Sun Jun 05, 2011 5:03 pm
(2x the distance between the centers of the wheels) plus (the diameter of a wheel x pi). Do it with the tensioning wheel raised about 1/3 of the way up from bottom.
PostPosted: Sun Jun 05, 2011 8:42 pm
First name: Big
Last Name: Jim
Take old blade and break in half , lay on floor and measure ! laughing6-hehe
PostPosted: Tue Sep 13, 2011 11:57 pm
I took the extension off and then had a machine shop remove 0.125" from each end. The 105" blades fit perfectly now.
PostPosted: Wed Sep 14, 2011 7:44 am
Good fix Steve! Now you can use standard size blades.
PostPosted: Thu Sep 15, 2011 11:36 am
That's what I was hoping for. Without the riser the saw used a standard blade length. I did not want to have to order a custom length.
Users browsing this forum: Burton LeGeyt and 86 guests
