It is currently Wed Aug 13, 2025 11:23 pm
PostPosted: Sat Jul 09, 2011 2:50 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I found some micro-chisels and thought of cutting rosette by hand. So I got a circle scriber (a circle cutter with a blade on it) and some 1.5 and 3mm chisels. I did a practice run on a piece of flat sawn spruce. The circle scriber kind of jumped a bit when it encountered the grain, and the cut at first wasn't so smooth, so I did the channel with the bevel against the wood and it worked better.
Anyone care to share some more tips on cutting rosette channel by hand?
Typhoon Guitars
PostPosted: Sat Jul 09, 2011 6:10 am
I'm not sure what you mean by micro chisel, but my limited experience is that a small, but not "micro" chisel is easier to handle.
PostPosted: Sat Jul 09, 2011 6:16 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
its a 1/16" and 1/8" chisel, any bigger and it wouldn't be small enough to fit inside the channel...
Typhoon Guitars
PostPosted: Sat Jul 09, 2011 6:32 am
You have to do multiple passes with the circle cutter. The first one being only to scribe the wood, as light as you can so the blade does not wander following the grain, then as you get deeper add more pressure. Practice on vertical grain spruce, as it is what you'll encounter on a top, and is more difficult.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Sat Jul 09, 2011 7:11 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Are there any single bevel razor blades out there that I can get for the circle cutter so I can only cut on one side (and switch to an opposite bevel for the other side)?
Typhoon Guitars
PostPosted: Sat Jul 09, 2011 7:52 am
Country: Romania
Here is a good talk about this:
http://www.delcamp.us/viewtopic.php?f=11&t=60338
Build log
PostPosted: Sat Jul 09, 2011 8:56 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
After some practice runs... I think some modification to the tools are necessary:
I need some ways of limiting the depth of cut... I think I will place a piece of wood on the blade and poke the blade through, so that only a little bit of the blade protrudes.
I also need a blade that has a flat side so that it lays against the good side, to get a vertical channel... but unfortunately the circle jig only comes with double beveled blades.
I don't have a grinder so how can I make a blade that fits? The blade fits inside the circle cutter with a set screw like so:
Maybe I should just buy the blade for the LMI cutter?
I will also ditch the center spike and simply drill a hole in the center that matches the center pin to avoid the center coming off...
Typhoon Guitars
PostPosted: Sat Jul 09, 2011 9:06 am
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I do my rosettes by hand, heres a pic of my rather primitive set up
PostPosted: Sat Jul 09, 2011 9:28 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Looks really good... I don't think a router jig would offer this kind of flexibility...
Those two cherries chisels are really good...
Typhoon Guitars
PostPosted: Sat Jul 09, 2011 10:23 am
Nice Oval! You'lll have to give me some rosette tips!
Old growth, shmold growth!
PostPosted: Sat Jul 09, 2011 11:13 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Oval, brilliant!
Didn't cost much either!
[clap] [clap] [clap]
PostPosted: Sat Jul 09, 2011 7:39 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
thanks, its simple and easy to do as well as affordable. BTW, the 2 cherries are great, the best and most used tools I own.
Users browsing this forum: DennisK, Dmaxwell and 29 guests
