It is currently Fri Aug 15, 2025 12:12 pm
PostPosted: Mon Aug 29, 2011 11:30 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I was thinking of using 2 nice spalted sycamore veneers to put on a flamenco instead of the tradional cream colored or clear vinyl plates . Anyone else done this before ??. Just wonderin ?
PostPosted: Mon Aug 29, 2011 2:27 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Ernie.
Those will be fine if they are not heavy -or thick.
Those tops need to be alive!
Mike Collins
PostPosted: Mon Aug 29, 2011 3:44 pm
I think your wood veneers will split or dig out over the years.
PostPosted: Mon Aug 29, 2011 3:50 pm
Well a typical veneer is about 5 times as thick as the normal mylar sheet so you are adding significant mass.
The spalted areas may also be soft and it could end up looking shabby quickly.
With a flamenco it is not unintended contact , but deliberate tapping with the nails
I would stick with mylar
PostPosted: Mon Aug 29, 2011 4:42 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
How thick is the mylar .0015?? the veneers are not punky but about.045
PostPosted: Mon Aug 29, 2011 5:08 pm
Well the stewmac mylar is listed as 0.005" thick
The "strings by mail" sheet I used on my flamenco measures at 0.010" installed (though the website incorrectly says .010mm)
PostPosted: Mon Aug 29, 2011 5:28 pm
First name: Sondre
Country: Norway
+1
When I started playing flamenco, I used a cheap plywood guitar without a golpeador, and I dug through the outer veneer after just a couple of months. Even on my current flamenco guitar the finish and wood fibers are all mashed up and uneven underneath the golpeador.
PostPosted: Tue Aug 30, 2011 8:16 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Thanks for the feedback sondre , any other flamenco players out there ??
PostPosted: Tue Aug 30, 2011 8:39 am
I'm not a Flamenco player but I am building a Flamenco guitar at the moment. A friend of mine is a good Flamenco player and she's pretty brutal on the sound board. IMHO if there is one place on a guitar where plastic is acceptable, even desirable, it's the pick guard or tap plate. Not only is it lighter as was mentioned but it's acoustically dead and a lot more resistant to finger nails et cetera.
PostPosted: Tue Aug 30, 2011 9:22 am
First name: Patrick
Last Name: Hanna
State: Missouri
Please allow a sidebar question: What was the traditional material for the golpeador? I'm talking about the days before plastics were available. I never really thought about this until reading this thread. Thanks.
Patrick
PostPosted: Tue Aug 30, 2011 10:07 am
Tortoise maybe?
PostPosted: Tue Aug 30, 2011 4:34 pm
Celluloid was available from the late 19th century.
As I understand, this was the period when Flamenco guitar technique was starting to develop.
So there may have been no predecessor to the plastic tap plate, it may have allowed full development of modern percussive flamenco techniques.
PostPosted: Tue Aug 30, 2011 4:39 pm
As a child, I tapped on the bridge extension.
PostPosted: Tue Aug 30, 2011 5:26 pm
First name: Jim
Last Name: Kirby
Early flamenco guitars were considered to be fairly disposable, yes? Concern about what golpeador to use to maximize the combination of playability and longevity is probably a very recent concern, possibly post-plastic?
Jim Kirby
kirby@udel.edu
Users browsing this forum: Powdrell1 and 13 guests
cron
