It is currently Wed Aug 06, 2025 11:12 pm
PostPosted: Tue Sep 13, 2011 9:04 am
To follow up the binding thread, any tips on hiding the joints on light colored binding like Maple?
I have seen very few guitars where the joints weren't pretty obvious, especially around the end graft.
PostPosted: Tue Sep 13, 2011 9:17 am
Don't use CA glue. HHG will make a less dark joint.
PostPosted: Tue Sep 13, 2011 10:30 am
First name: Danny
Last Name: Vincent
I have the best results by sanding the butts with 220 on a hard block and then glueing with white glue. I have made one that was all but invisible. It ended up under the tail piece of a mando. :(
PostPosted: Tue Sep 13, 2011 11:25 am
Terence, I usually do a scarf joint where the binding meets at the butt. Gluing dry with CA will result in a dark line, no matter how perfect the joint is. I wet the maple before applying TB1 or Gorilla wood glue. BTW that works well for purflings as well.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Tue Sep 13, 2011 11:26 am
Perhaps make a feature of it.
Thinking a small dark piece scarfed it at the tail, top and bottom, maybe aligned with the tapered tail graft - come to think of it, my next binding is light coloured.......
Thanks!
PostPosted: Tue Sep 13, 2011 12:09 pm
I agree with Laurent. Make a scarf instead of butt joint.
michael propsom
www.propsomguitars.com
PostPosted: Tue Sep 13, 2011 12:17 pm
ME too - and make the joint several inches off the center line.
I'd use LMI white glue for this.
PostPosted: Tue Sep 13, 2011 6:24 pm
Thanks guys, Charlie Hoffman sells in the same store I'm in and he also scarfs his maple bindings. They are the best joints I've seen so far. That's what I'll do. I appreciate the help.
PostPosted: Tue Sep 13, 2011 9:54 pm
Todd,
Can you tell us if you are using a jig or some type of Miter Trimmer to cut that scarf joint, it's outstanding work.
PostPosted: Wed Sep 14, 2011 10:53 am
First name: Mark
Last Name: Schrier
State: Washington
Thanks for explaining your technique, Todd.
I'm not quite sure that I understand how you are using the tape shims. Could you explain that further?
Mark
A world without music would Bb.
