It is currently Thu Aug 21, 2025 5:54 am
PostPosted: Mon Oct 10, 2011 4:40 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I fixed a Les Paul that needed splines to reinforce the fix due to a previous attempt at "fixing" it (done by an incompetent "luthier").
Obviously it had to be spot-refinished because the spline was ugly, so I covered it with black burst to make it less obvious.
Les Pauls are easy because they were finished with Nitrocellulose lacquer.
Hypothetically, if I were to receive another instrument in a similar condition which requires splines and a partial refinishing, but was finished in cat poly (which sort of represent about 98% of all low to medium end factory instruments out there, even many high end instruments like Taylor), how can I do a partial refinish for a cat poly instrument? I can't spray cat poly so that's out of the question, but I could use lacquer. For touch ups it's less of a deal but what about a partial refinish?
Do I strip down the entire neck, refinish it, and charge higher for those?
Typhoon Guitars
PostPosted: Tue Oct 11, 2011 12:03 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I think you have two options...either strip and refinish or overspray the entire neck. It is possible to spray lacquer over cat poly, but I would sand with 180 or 220 to create a good mechanical bond.
