It is currently Wed Aug 20, 2025 10:28 am
PostPosted: Tue Oct 11, 2011 8:17 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Does anyone have any experience with the Taylor 5525 Mason Hygrometer? http://www.partshelf.com/taylor55251.html It seems inexpensive and I have read claims of 100% accuracy.
I am looking for a good accurate hygrometer for my shop to check my dehumidifier. After searching the forum threads I realized that buying and maintaining a hygrometer is much more complicated than I anticipated. I would appreciate any advice. Thanks!
PostPosted: Tue Oct 11, 2011 8:44 am
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Check with the 12th Fret in Toronto. They sell good ones for about $80 (IIRC). They'll ship to you, and you can ship them back yearly to be recalibrated for free.
PostPosted: Tue Oct 11, 2011 9:30 am
Wet/Dry bulb hygrometers have been around for decades and are extremely accurate; you just have to put a little water in the reservoir from time to time. Weather "enthusiasts" have been using them since Noah's Arc hit a rock...
pvg
PostPosted: Tue Oct 11, 2011 1:34 pm
I wouldn't recommend that particular version. With only 2 degrees accuracy, you're opening yourself up to an instrument that will only give you answers within +/- about 20% humidity. A 4 degree swing in difference between the two, is a big difference when you are in the working range. Every degree is about 2 to 3% in humidity. I have a cheap one that has 1 degree markings and has both C and F scales. It allows a bit closer observation, but may still be inaccurate because it's a cheap model.
PostPosted: Tue Oct 11, 2011 2:57 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Seems like all the wet/dry bulbs have 2% tick marks. How about a good quality hair hygrometer? http://www.ambientweather.com/fikf103pmh.html
