It is currently Tue Aug 05, 2025 9:40 pm
PostPosted: Tue Oct 11, 2011 8:19 pm
First name: micah
Last Name: medlong
City: parma
State: ohio
Zip/Postal Code: 44129
So after gluing my X brace on I realized I made it to tall [headinwall] [headinwall] and when I carved it down the joint wouldn't be right.
so what the best way to remove it with out scrapping the top?
PostPosted: Tue Oct 11, 2011 8:24 pm
Keep carving.
Chisel,plane, sand paper...
PostPosted: Tue Oct 11, 2011 8:38 pm
Why won't the joint be right? As long as you've got wood glued to wood and capped you should be just fine... idunno
Are you assuming that the joint between the two MUST be at the center between them??? Someone please tell me why you'd need to make the lap joint equal on both pieces....?
PostPosted: Tue Oct 11, 2011 8:42 pm
What Rod says, is True!
Sorry, bad pun, but good advice.
PostPosted: Tue Oct 11, 2011 11:22 pm
First name: micah
Last Name: medlong
City: parma
State: ohio
I thought that the over lap has to be the same on both sides for strength. oops_sign
PostPosted: Wed Oct 12, 2011 5:11 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Nope, if the bracing is otherwise good - just too tall, I would just plane/chisel it down and then cap the joint. Can't see how that would be a problem.
Mark
PostPosted: Wed Oct 12, 2011 7:28 am
First name: micah
Last Name: medlong
City: parma
State: ohio
Ah dang it!!! I already started to remove it and even cracked the edge of the top. Hopefully I can fix it.
PostPosted: Wed Oct 12, 2011 4:48 pm
First name: micah
Last Name: medlong
City: parma
State: ohio
I cracked the edge about 20 inches in then gain another inch in. should I use my lmi white glue or CA glue?
PostPosted: Wed Oct 12, 2011 5:47 pm
That crack sounds like you split the top in half...
Use the LMI white to repair, CA doesn't fix cracks on soft wood well IMO.
PostPosted: Wed Oct 12, 2011 6:37 pm
First name: micah
Last Name: medlong
City: parma
State: ohio
Yeah it's a split. Didn't break it all of the way off tho
PostPosted: Wed Oct 12, 2011 6:58 pm
Well, work glue in the split as best you can without opening it up anymore. Put some weight on it and pull the pieces together.
Users browsing this forum: Bing [Bot], dofthesea, Gasawdust and 38 guests
