It is currently Sat Aug 02, 2025 6:53 am
PostPosted: Fri Oct 14, 2011 10:02 pm
Last Name: coloccia
Country: States
I'm thinking of just buffing and waxing it but I'm concerned about wax getting trapped in the pores. What's the right thing to do here? Maybe a couple light coats of shellac? The rest of the neck is tru-oil. If I seal with shellac, can I Truoil over it?
PostPosted: Fri Oct 14, 2011 10:08 pm
Last Name: coloccia
Country: States
Maybe even just some Stewmac fretboard oil and buff?
PostPosted: Sat Oct 15, 2011 5:48 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
For an easy, but good looking finish I'd recommend pore filling with the method of your choice, and spraying it with rattle can lacquer. I doubt the tru oil will cure on Cocobolo. (I'm assumeing you don't have spray equipment. If you do just spray it with any evaporative finish)
PostPosted: Sat Oct 15, 2011 6:08 am
Last Name: coloccia
Country: States
I can spray. I just didn't really want to go through a spray, cure, buff cycle with this. If I do shellac, I can buff out the next day, so maybe that's what I'll do.
PostPosted: Sat Oct 15, 2011 7:01 am
Last Name: Kincheloe
First, just polish it up by sanding with wet/dry paper up to 1500 or whatever. Wipe on a thin coat of shellac and let it dry. Then take a scrap of muslin or similar fine cotton cloth and wad it up into a little pad. Put a couple drops of alcohol on it (just barely damp) and rub the surface with hard and fast circular motions. Shines up real good, by slightly softening the shellac surface and burnishing it out. And no risk of trapping buffing compound in pores :)
You could also pumice fill before the rub down, and/or French polish up a thicker shellac layer than the initial wipe, but I think cocobolo would look just fine with open pores and the simple rubbed sealer.
PostPosted: Sat Oct 15, 2011 6:54 pm
Filippo Morelli wrote:
Epoxy or CA pore fill. Then wipe whatever you want over it.
Filippo
Except Liberon Oil finish. It will turn to goo over Zpoxy! DAMHIKT gaah
