It is currently Sat Aug 09, 2025 6:32 am
PostPosted: Thu Dec 01, 2011 10:10 pm
First name: Corky
Last Name: Long
City: Mount Kisco
So what if I like the feel of a Tru Oil neck, but lust for the gleam of a deep, buffed sprayed finish on the front and back of the headstock? Do any of you Tru-Oil neck polishers spray your headstocks?? Of so, how do you manage the overspray, or the margin between the two finishes?
Am I making this too complicated? Will a deep, buffed Tru-Oil finish on the headstock look like "the real thing"? So far, after about a dozen coats of Tru Oil, it doesn't seem so. Tru Oil seems to look better on a curved surface than a flat one... Headstock looks a bit anemic, but the neck looks like the surface of a pond at dawn.....
PostPosted: Thu Dec 01, 2011 11:47 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
I true oil the neck and back of headstock. That transition could be problematic. I lacquer the top of the headstock. The transition doesn't seem to be a problem for me. I'm putting the final coats of true oil on last. If you don't pore fill the neck and put a couple coats of shellac on after that you will have to put 80 million coats of true oil on to get a decent finish and could have problems with true oil directly over epoxy as some have had.
http://goatrockukulele.com
PostPosted: Fri Dec 02, 2011 12:08 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
You've got tru oil on da headstock.
Can't turn back now.......
PostPosted: Sat Dec 03, 2011 7:47 am
First name: Ron
Last Name: Belanger
I like to oil my necks - Waterlox. And I French Polish the headstock veneer. I apply the oil daily for a week or so and fp at the same time. works for me.
PostPosted: Sat Dec 03, 2011 12:39 pm
First name: Stuart
Last Name: Gort
Seems to me that due to adhesion issues the only way to acheive a transition between Tru-Oil and lacquer would be to fully finish the entire thing with lacquer and then artfully sand back the nitro in the transition area....back to wood....then apply the Tru-Oil. I thought about trying this before but I can never remember to spray test panels when I'm finishing a guitar. :) Honestly....I don't put too much stock in this working out. I think it would get ruined in the polishing stage in the transition area between Tru-Oil and nitro. I don't see how it could polish out nicely without a messy looking transition. I think the best chance would be to fully polish the nitro, carefully sand back (this would be tricky going thiough the grades), apply Tru-Oil to the bare wood, and hope for the best in the transition.
What's wrong with skipping the Tru-Oil and scuffing the back of the lacquered neck with 0000 steel wool? It has more or less the same feel and it seems fifty times easier. :)
StuMusic
Users browsing this forum: Colin North and 47 guests
