It is currently Wed Aug 20, 2025 8:18 am
 Post subject: Dovetail neck by hand
PostPosted: Sat Dec 24, 2011 11:15 am
First name: James
Last Name: Lee
City: Atmore
State: AL
Zip/Postal Code: 36502
Anyone know of any instructions for doing a dovetail neck by hand? Most of the instructions that I can find use a router and templates. Any pointers will be appreciated.
James
PostPosted: Sat Dec 24, 2011 11:36 am
Here's one...
http://gicl.cs.drexel.edu/people/sevy/l ... joint.html
PostPosted: Sat Dec 24, 2011 1:49 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Tage Frid has a tutorial in one of his books of how to cut a dovetail by hand . He uses a special ece/primus dovetailplane that tilts at 10 deg angle on either side and has a depth stop adjustment mechanism .The waste is removed with a vy sharp chisel.The book is put out by fine woodworking, and can be borrowed via your local or interlibrary loan
PostPosted: Sat Dec 24, 2011 5:20 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
For the block I would scribe out the lines and take the waste with a forstner bit, clear the bevels with a good sharp chisel. Would prefer a dovetail chisel to a bench chisel, but either could do the job. The neck is much easier, layout & saw with a good backsaw, maybe clean with a chisel depending on how good your saw is.
Brian
PostPosted: Sat Dec 24, 2011 7:44 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I've read about using a bandsaw to cut dovetails... I wonder if that would work...
Typhoon Guitars
PostPosted: Mon Dec 26, 2011 9:35 am
I took some pictures when I did this archtop...
Marking the dovetail on the neck blank
Sawing just outside the lines
Result
Cutting the mortise in the body, before cutting the waste out (router, forstner bit, chisel will all work)
"Chalk fitting" the joint, chisel to fit
Using a centerline jig to check the sideways alignment. A straightedge is used to check the neck angle / projected string height over the top
When everything fits, the neck can be glued in with a single clamp
PostPosted: Mon Dec 26, 2011 1:15 pm
Very nice Riant!
There is a short section on Jimmy D'Aquisto building an archtop in the back of Irving Sloanes "Steel String Guitar Construction" book that is the same method as Riant, only using western style back saws.
-C
Freeborn Guitars
and home of BeauGuard©
PostPosted: Tue Dec 27, 2011 6:53 pm
Last Name: Howard
City: Magnolia
State: Delaware
Nice vise!
Brian
PostPosted: Tue Dec 27, 2011 6:54 pm
First name: Patrick
Last Name: Hanna
State: Missouri
You bet it's a nice vise! Wow! It's so beautiful, I'd almost be scared to use it.
PostPosted: Tue Dec 27, 2011 8:37 pm
Last Name: Hill
City: Wesley Chapel
State: Fl.
Zip/Postal Code: 33543
Mr. Rian,
The Plexiglas guide you are using ...is that for alignment of the neck and body?
Joe
My wife asks me "How many Guitars do you need?"
I reply "When I die count them; thats how many I needed".
PostPosted: Tue Dec 27, 2011 8:42 pm
First name: Jim
Last Name: Hansen
It is a centerline finder and bridge locator from Tracy Leveque at Luthiersuppliers.com
http://www.luthiersuppliers.com/products/p9.html
Jim Hansen
PostPosted: Tue Dec 27, 2011 9:23 pm
Last Name: Hill
City: Wesley Chapel
State: Fl.
Thanks for the link and info that tool looks to be a real time saver Jim.
Joe
PostPosted: Wed Dec 28, 2011 8:16 am
arnt, some things never change; in this case the wow factor in your work. always a pleasure to see the photos of your work.
PostPosted: Wed Dec 28, 2011 2:19 pm
Hear, hear!
Users browsing this forum: phavriluk, pkdz, Robbie_McD and 11 guests
