It is currently Sun Sep 21, 2025 5:35 pm
 Post subject: Worm holes
PostPosted: Tue Jan 10, 2012 1:03 pm
I have a bubinga back that has a few small through wormholes. Should I fill these? If so ,with what?
 Post subject: Re: Worm holes
PostPosted: Tue Jan 10, 2012 1:10 pm
First name: Ron
Last Name: Belanger
pack the holes with fine Bubinga dust and flood with thin CA. Level and repeat if necessary.
PostPosted: Tue Jan 10, 2012 1:21 pm
Its kind of a futile effort. You can fill them with dust, but that dust will just go through the worm hole and re-appear at some different point in the space-time continuum.
Ive done what Ron suggests though. Put some tape on the back side
Or you could leave them and consider them tiny sound ports.
PostPosted: Tue Jan 10, 2012 3:09 pm
Here's a link to an article on Allied's site that discusses ways to fill wormholes. I found it interesting...
http://www.alliedlutherie.com/filling_a_hole.htm
PostPosted: Wed Jan 11, 2012 8:44 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I tried filling wormholes but the fill ended up getting transported to the Gamma Quadrant...
Typhoon Guitars
PostPosted: Wed Jan 11, 2012 9:50 pm
Last Name: Cox
You have a couple solutions....
Do you want to highlight the worm holes or do you want to try to hide them or make them less obvious....
If you want to highlight them - use epoxy and a dye and fill them with something dark or a very strong contrasting color... Black or dark brown seems to work well...
I don't like Epoxy/sawdust mixes as much - as they tend to look like grit or pencil shavings mixed into a clear solution.... but they are very easy to work with.... You have a much longer open time than superglue....
Last is to pack the hole with sawdust and then wick in a thin superglue... This looks more like it's "Supposed to" in my mind... It can be a challenge too - as sometimes the dust wants to float out...
I tried pre-mixing sawdust with superglue - then packing it in the hole... It kicked over about 25% of the time and foamed up in the hole....
Superglue whets the wood - so you get a darker color... Epoxy doesn't whet the wood as much - and it tends to be lighter than the wood surrounding it....
YMMV...
PostPosted: Wed Jan 11, 2012 10:27 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I think a photon torpedo will collapse a wormhole...
Typhoon Guitars
Users browsing this forum: bftobin and 44 guests
