It is currently Fri Aug 01, 2025 12:52 pm
 Post subject: fixing a sand through
PostPosted: Sat Jan 14, 2012 1:18 pm
First name: Jeff
Last Name: Hewitt
Zip/Postal Code: 37312
So I sanded through a spot on my top today [headinwall] ....I have masked the sides to respray again. Should I respray several coats paying more attention to the area I went through, or should I sanded to whole top down and go from there? I'm useing em2000 varnish if that makes a difference in what I should do.
PostPosted: Sat Jan 14, 2012 1:25 pm
State: Tennessee
If it were mine I would redo the entire top.
PostPosted: Sat Jan 14, 2012 2:10 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Yep, but first you need to figure out why you sanded through. Either uneven finish application, uneven sanding or bad prep before finishing.
PostPosted: Sat Jan 14, 2012 5:34 pm
First name: Madd
Last Name: Mike
Some pics would be useful 8-)
Mike :)
(MH)===:::
PostPosted: Sat Jan 14, 2012 10:13 pm
First name: Aaron
Last Name: Craig
State: Missouri
I would probably redo the whole top. But, if there are no color matching issues, and the sand-through was in the upper bout, I'd think about just reshooting the affected area (feathering the finish over a larger area).
Aaron Craig
PostPosted: Mon Jan 16, 2012 8:11 am
What kind of finish? Was there a colored seal coat underneath? (shellac)...
If you finish melts into intself (nitro) and there was no coloring, you can just reshoot. It might show, but not be glaringly obvious to anyone but you, the nature of wood being what it is.
If it was however a finish that dries in distinctive layers, like polyurethane and such, then you'll have to re-sand and start anew. You'll always have witness lines.
If there was any kind of color underneath, I'd say sand back to wood.
Users browsing this forum: CarlD and 6 guests
