It is currently Mon May 11, 2026 12:13 pm
 Post subject: omega heating blankets
PostPosted: Sun Jan 22, 2012 4:45 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I was thinking of buying a 2 in by 18 heating blanket for bending rope binding.The test samples I tried to bend on my luthiers alum bending iron failed.When I looked at the omega website the bending blankets come in 2.5 watts 5 and 10 watts. Does anyone know what that translates to in temp i.e. degrees F. ?? My plan was to make a plywood circle and bend the rope binding around it using the small heating blanket. Anyone out there done this?
PostPosted: Sun Jan 22, 2012 5:28 pm
No .. but I use the 2.5 watters exclusively .. I see no need for the 5 watters. The 2.5 will get wood up to 300 degrees or so in a couple minutes, and the wood is ready to bend. I use the 2x18 for small binding pieces in dedicated molds for armrests and ribrests.
PostPosted: Mon Jan 23, 2012 12:02 pm
All the blankets get hot enough and pretty quickly. The watts per square inch relate to how many amps they will draw. For a typical 36X6 inch blanket the 10w/sq.in. might draw 18 amps under full load, and overload a 10 amp circuit or one with multiple appliances being used at the same time. A 2X18 inch blanket would draw considerably less.
I use the 2.5 w/sq in. blanket and it works fine.
PostPosted: Mon Jan 23, 2012 12:28 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Thanks for the explanation on amp draw.I have a watlow 6 by 36 I run it at abt 325 , and can only use 1 line on a 15 amp circuit.The bigger blanket is probably drawing close to the 15 amp limit, as the plug wire is always warm.
PostPosted: Mon Jan 23, 2012 1:22 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
What is the watts per square inch of your blanket? I ask because I have a 6 x 36" Watlow blanket (2.5w per square) and am relocating my shop space. I'm wondering If I will have trouble with the 15 amp circuit that is run to the area I want to do my bending in. I suppose I could move the bending station to be by the 20 amp circuits but I'd rather not. . .
Bryan Bear PMoMC
PostPosted: Mon Jan 23, 2012 2:40 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Bryan I bought the same heating blanket from watlow, when we lived in valley park. Personally I have used the 6by 36 often ,it is hooked up to a large dimmer switch.,I.m guessing but I never let it get over 350 on the blanket , I use a thermometer, and then shut it off, if the side is not bent when cooled .I give it another try.I would err on the side of caution, and use 20 amp line.When I ran my plug through a 4 plug circuit box,it would frequently, once heated up, shut down.Now I use it with a heavy duty extension cord on a 15 amp line. Havenot tripped the circuit breaker box
PostPosted: Mon Jan 23, 2012 2:58 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Thanks Ernie. I'm getting ready to build the counter space for the shop now, so I still have some flexibility. It would have been nice if we had talked about this before the drywall was done. gaah
Bryan Bear PMoMC
PostPosted: Mon Jan 23, 2012 5:13 pm
I use 5 watts per in and use a controller. That allows you to dial in the temp you want.
PostPosted: Mon Jan 23, 2012 5:51 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
bryan I have a ham radio licence for 48 years. A really good friend is a master electrician.If you have a question PM me and I can run it by my electrician friend. ernie
PostPosted: Tue Jan 24, 2012 8:29 am
well .. do the math here - 6x36 = 216 ... x2.5watts per = 540 watts. A 15 amp circuit at 120 volts gives 15x120=1800 watts of potential power ... you wont even cause a blip using that blanket... no need for 20 amp circuit.
PostPosted: Tue Jan 24, 2012 11:03 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Tony you are correct.in your calculations. I had an electrical fire in a home in van bc, that had a seperate circuit for the dryer.Unbeknownst to me, the previous owner had spliced in another line that was in my then work area.Since then I always err on the side of caution especially when it comes to electrical outlets, and listening to horror stories from my electrician friend.
PostPosted: Tue Jan 24, 2012 11:22 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Thanks Ernie and Tony. I often run my blanket and bending iron at the same time. Looking at the calculations Tony provided, I should still have enough "headroom." I doubt, I will be using much else from that circuit if I am busy bending so I should be fine. The first time I trip the breaker (if that ever happens) I will re-evaluate. . .
Bryan Bear PMoMC
PostPosted: Tue Jan 24, 2012 12:04 pm
I also have all my wiring at 20 amp circuits and underloaded. I would rather a box full of breakers than an overloaded circuit. I don't have any 14 wire in my house or shop. I know it may be safe but I would rather be on the safety side.
Users browsing this forum: No registered users and 97 guests
